ordering parts
- **BANNED**
Rear half of E30 prop(bit that carries the centre bearing)is common to all versions,it's the front bit that changes length and fitting to suit.
GSF or ECP will be able to supply a suitable part,bearing and the rubber-lined carrier are two seperate bits,and you will only be able to get the dust cover thingy from the main stealer.
Youth is wasted on the young.
- Brianmoooore
There's only two versions of the prop centre bearing, and that's pre and post facelift. The difference is in the spacing of the bolt holes.
- Brianmoooore
Bearing mounts on the chassis, so it's a post facelift you need.
Not really a part I'd advise buying second hand.
P.S: I've just noticed that you mention a u/j in your OP. These aren't replaceable, so if one has failed you'll need a whole fresh prop - not just the half that's failed, as the prop is balanced as a complete item.
