wrong engine mounts = drifting fail :(
newt
Mon May 23, 2011 1:23 pm
well i went out for a play in my e30 m50 last night, i knew my mounts were abit soft but though it will be okay as it only scrubs a little on tight left handers, so off i went to a nice big roundabout with my mate in his 200sx,
was all going well till i decided to try and drift off the exit from the roundabout,
so there i was full lock left on the roundabout when i flicked it the other way to exit and my engine shifted over causing my exhaust to lock my steering linkage where it was, i couldnt straighten out and span up the curb in my rather low e30 :(
pictures show the damage :/
and now i have 4days to rebuild it before rtts, mission on :twisted:
kids on the back seats cause accidents, accidents on the back seats cause kids
Mon May 23, 2011 1:26 pm
That hit hard 8O
If your going to be diffin/driving abnormally you will need much stronger mounts, I thought you had bought an RPM guard?
newt
Mon May 23, 2011 1:27 pm
i had a sump gaurd but it wouldnt clear my sump :/ yeah those are m5 mounts, gunna hocky puk it i think as i dont have the 130dollars for the solid ally mounts
Duke137
Mon May 23, 2011 3:46 pm
Oh dear....
Which mounts were they? ECP ones?
All that work on those wheels aswell! That is exactly why I don't drift my E30 as I just know I would wreck it. fiar play though with getting stuck in to repair it!
eko
Old timer
Mon May 23, 2011 3:52 pm
Ouch 8O
newt
Mon May 23, 2011 4:03 pm
Duke137 wrote:Oh dear....
they were just round m5 ones with half inch spacers on top,
ive got another 2 of those wheels so its not too bad, and i have a sump sat at home, just need better mounts and an engine arm :)
Mon May 23, 2011 6:27 pm
:rofl: major fail !!!
reminds me of this clip,
[youtube][/youtube]
Cook318IS
Mon May 23, 2011 6:30 pm
DanThe wrote:
newt wrote:heres one that gives you a better idea, and yes that is a normal sized yoghurt pot and no it wont fit under the sump... even on its side
This could be messy :eek:
Dan the fortune teller!
That must of been one hell of an impact to fuck the engine arm up too
newt
Mon May 23, 2011 6:34 pm
yea was 2nd gear about 40, as i came of the roundabout and went to straighten up it was stuck full lock so just ploughed me straight into the curb, should have it back on the road for the weekend though :) round 2 haha this time with some solid mounts!
Mon May 23, 2011 6:47 pm
Have you modded the steering linkage at all?
newt
Mon May 23, 2011 6:57 pm
nah its just one your linkages with two e34 universal joints,
Duke137
Mon May 23, 2011 10:53 pm
Have you checked the car thoroughly as I wouldn't like to gamble the damage stays with a couple of alloys, your sump and an ally mounting arm....
8O
newt
Mon May 23, 2011 11:23 pm
Duke137 wrote:Have you checked the car thoroughly as I wouldn't like to gamble the damage stays with a couple of alloys, your sump and an ally mounting arm....
8O
nah ive had a quick look around. cars being towed back to mine tomorrow and ill pull the engine out an see what the rack and subframe is looking like, fingers crossed, ill post some pics up as i go
craigieeb
Mon May 23, 2011 11:32 pm
Owch,
nice work
:P
Where did you get the mounts?
BMW, GSF ECP etc ?
newt
Mon May 23, 2011 11:45 pm
craigieeb wrote:Owch,
nice work
:P
BMW, GSF ECP etc ?
they were b15nac's on here so i have no idea where they came from, he wanted to try out mk2 escort ones and i had e34 525 ones so bought his old m5 ones were only a few weeks old,
rob0r
Tue May 24, 2011 12:42 am
Nasty! I've used hockey pucks to good effect with my M50 (in my E21).
B15NAC
Tue May 24, 2011 9:16 am
yea i used them on mine for about 2 weeks but mine has a standard e30 steering u/j set up so mine hit when cornering hard so i went for harder ones instead of changing my u/j i saw you wanted a set of e28 m5 mounts as you were using e34 ones so thought they would be fine with your set up! i was told that the e28 m5 mounts are the ones to have! :?
Duke137
Tue May 24, 2011 10:07 am
B15NAC wrote:yea i used them on mine for about 2 weeks but mine has a standard e30 steering u/j set up so mine hit when cornering hard so i went for harder ones instead of changing my u/j i saw you wanted a set of e28 m5 mounts as you were using e34 ones so thought they would be fine with your set up! i was told that the e28 m5 mounts are the ones to have! :?
Where did you get them from? Sounds like they might not be E28/M5...
newt
Tue May 24, 2011 11:01 am
yeah the m5 mounts are normally fine, not your fault mate :) ive just picked up my new engine arm, went and had another nose around the car, everything looks to be okay, not 100% on the rear subframe though so may be changing that but the front subframe and steering rack all seem okay :)
pauldeacs
Tue May 24, 2011 1:15 pm
bound to of bent the wishbone i would of thought, ive clipped kerbs at much lower speeds in e30s and e36s and ended up with bent wishbones.
newt
Tue May 24, 2011 1:17 pm
pauldeacs wrote:bound to of bent the wishbone i would of thought, ive clipped kerbs at much lower speeds in e30s and e36s and ended up with bent wishbones.
the front wheel hit head on... ish, and only dented but the back swung in side on hence it snapped :L
bmw320iSE
Wed May 25, 2011 1:29 pm
e30topless wrote::rofl: major fail !!!
[youtube][/youtube]
That made me laugh so hard its brilliant never seen that before :mad:
will be watching it over and over again now
si911t
Thu May 26, 2011 11:43 pm
[youtube][/youtube]
funny as fck !
I actually nearly pissed myself laughing after watching that , brilliant !
German-Whips
Thu May 26, 2011 11:58 pm
[youtube][/youtube]
funny as fck !
Haha, it's like the american lowriders with the hydraulics! :mad:
