Which radaitors do you use?
Sun May 22, 2011 8:57 pm
As the topic out of interest what radiators do you use?
littlechef
Sun May 22, 2011 9:38 pm
I have used a 740i item but the front needs cutting and boxing to make fit as it is much wider than any e30 item
200272
Mon May 23, 2011 12:27 pm
Cheers, i cannot fit the 540 rad, i need a shorter rad, will i need something similar in literage or can i slap in anything???? I am going to run a Kenlow fan in front of the Rad.
Cheers.
chips
Was Pzero
Was Pzero
Mon May 23, 2011 1:27 pm
I think the E36 M3 radiator fits between the chassis legs
Phill172
Mon May 23, 2011 1:32 pm
It does, I have one in mine
chips
Was Pzero
Was Pzero
Mon May 23, 2011 1:37 pm
I knew I'd read about it somewhere :)
200272
Tue May 24, 2011 12:01 pm
willnz wrote:I have used an e28 535 a/c radiator in mine.
Hi do you have the measurements for the rad please.
Jonsku
Tue May 24, 2011 7:26 pm
I use custom-made radiator, clears the oil-filter housing nicely and offers better cooling capacity than the E28 M30 / E36 M3 items, which are not up to the task from my point of view.. Could be "fixed" with very powerful fan, though.
Modding the chassis legs for E34 540 radiator is not too bad job.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
200272
Wed May 25, 2011 10:20 pm
I am nowhere near my car right now, will post on saturday when I get back home.
Thanks :D
padi
Fri May 27, 2011 8:55 am
Hi guys, is there a reason why you use the e36 m3 rad over the 328 ones? Looked on realoem and it says they're the same size. Don't know if there's anynprice difference? Just curious as I've been offered a 328 rad cheap...
Cheers Chris.
200272
Sat May 28, 2011 1:55 pm
willnz wrote:E28 535 radiator is approx 490mm tall by 580 wide (at the top) The LHS tank tapers towards the bottom to approx 540mm which helps give clearance to the chassis rails.
Thanks that is perfect, any idea where i can get hold of one? 8)
Cheers.
leeparkes
Sun May 29, 2011 11:08 pm
200272
Mon May 30, 2011 6:28 pm
Cheers i have an offer of a rad from this site.
Skazka
Fri Jun 24, 2011 9:21 am
e28 535
