2.9 stroker pinging
Sebastian35
Post Tue May 03, 2011 1:03 am
Engine pinging and need help!
block fitted with m52 crank and rods, pistons are +1mm JE and head is 885. Need advice!
Kos
Post Tue May 03, 2011 1:08 am
try 99 ron fuel
failing that get it mapped
Sebastian35
Post Tue May 03, 2011 8:51 am
I am using 99 already! just need to get it run in so an dyno can tune it.
Post Tue May 03, 2011 9:06 am
DON'T POST THE SAME THREAD IN MORE THAN ONE FORUM!
Gunni
Post Tue May 03, 2011 10:34 am
You need mapping.
Which I can sort out for you.
With great challenges comes great engineering.
Gunni
@ 2012 VEMS group buy !!
Kos
Post Tue May 03, 2011 2:02 pm
if you are running it in the you dont need to drive it hard ( in some peoples opinion ) any way try an octane booster, or get the timing backed off a bit
what compression are you running , it must be bloody high to be pinking
finally, gunni is the man when i comes to mapping these.
Sebastian35
Post Tue May 03, 2011 4:00 pm
Brianmoooore wrote:DON'T POST THE SAME THREAD IN MORE THAN ONE FORUM!
Sorry I just wanted some help not stress for asking a question!
I wonder about this site sometimes as people can leap on you for such little things! Sorry sorry sorry!
Sebastian35
Post Tue May 03, 2011 4:06 pm
Kos wrote:if you are running it in the you dont need to drive it hard ( in some peoples opinion ) any way try an octane booster, or get the timing backed off a bit
The pining was instant as soon as I pressed th gas, so i could not drive at all, by no means am i trying to drive hard yet. Just want to get moving lol. Now with the war chip I can move just lol and should be able to run it in! The compression should be 11.2.1 I did a CR test and it went off the gauge around 250+psi will check again tomorrow!
Thank for the info so far guys and I would love some help with that tune please....
GeoffBob
Forced Induction Specialist
Post Wed May 04, 2011 3:20 pm
Sebastian35 wrote:I did a CR test and it went off the gauge around 250+psi
Suggesting that you have a CR in excess of 18:1 :!: No amount of tuning or additional octane will get you around this problem. You need to lower your compression ratio. Perform a compression test again with a quality gauge to be on the safe side and take it from there. If the numbers are as high as you say they are then don't even try to drive the car, you'll only damage your engine.
CHR1S1990
Post Wed May 04, 2011 3:47 pm
how did you get 18:1 geoff? I got somewhere between 10.3 and 11.5 depending on his choice of cam based on his cranking 250psi
CHR1S1990
Post Wed May 04, 2011 3:54 pm
should be getting between 210 and 240 PSI for 11.2:1, your cam being the varying factor
CHR1S1990
Post Wed May 04, 2011 4:33 pm
your reply has vanished geoff?
GeoffBob
Post Wed May 04, 2011 5:13 pm
CHR1S1990 wrote:How did you get 18:1 geoff?
By assuming a non-adiabatic process during compression Chris, an error on my part. Sebastian, please ignore my above post, I apologise for misleading you. I have a nasty habit of typing before thinking.
GeoffBob
Post Wed May 04, 2011 5:17 pm
CHR1S1990 wrote:your reply has vanished geoff?
By the time I finished typing my post you had already posted your next. It was then that I saw my mistake and took it down.
Are you assuming any heat lost to the cylinder walls in your calculation Chris (non-adiabatic process) or do you arrive at your value purely as a result of the delayed closing of the inlet valve (cam timing). No matter how I tried I could not arrive at your values. What value are you using for the ratio of specific heats?
CHR1S1990
Post Wed May 04, 2011 5:41 pm
No problem geoff, i thought somebody might have been tinkering with your posts thats all.
I was using a calculation i noted down a few months back I saw on the web:
Cranking Pressure (Psi) = CR^1.3 x 14.7 x 2/3
And.. as an estimate for cam overlap:
x .95 fast road cam
x .90 rally cam
x .85 full race cam
so for his 250 psi cranking pressure he should have seen somewhere between 10.3 and 11.5 CR
for his supposed 11.2 he should be looking between 212 and 238 PSI.
these are however, as youl agree, rough estimates as I am not sure how they arrived at the factors in the equation, or whether they take into account the adiabatic index. Im far from a mathematician/physicist as you can see, do you know a more accurate way of calculating the CR or vice versa? From what ive seen, you know your stuff!
CHR1S1990
Post Wed May 04, 2011 5:45 pm
edit: 1.3 is obviously the specific heat ratio
Gunni
Post Wed May 04, 2011 6:54 pm
I measured a M20B27 the other day and it measured more then 16bar. I have never seen anything like it, it made no more power then a kinda similar B27 that only measured in the 11s and they made about the same power at the same ignition advance.
The high pressure test one didn´t have any issues with detonation either.
Gunni
CHR1S1990
Post Wed May 04, 2011 6:57 pm
^ strange!
CHR1S1990
Post Wed May 04, 2011 6:58 pm
do you know the block/head specs gunni?
only thing i can think of is the obviously higher CR engine as an unsuited cam to be not making any more power?
GeoffBob
Post Thu May 05, 2011 11:00 am
Ziggy
Post Thu May 05, 2011 11:46 am
GeoffBob wrote:Apologies for the long post.
When you put that much effort into helping someone, the last thing you need to do is apologise! :)
GeoffBob
Post Thu May 05, 2011 12:52 pm
Ta!
CHR1S1990
Post Thu May 05, 2011 1:28 pm
GeoffBob wrote: At the very least (ignoring all the maths) it should give you some indication that your problem is tuning only (assuming your measurements are correct).
thanks for that geoff, makes perfect sense.
a little more info on his cam choice and we could be more accurate, but either way it seems his CR is around that of what it should be based on his piston choice and as you say, tuning is way off in this case. Sebastian you can rest assured you dont need to strip the block apart [edit] assuming your compression gauge readings are correct :cool:
GeoffBob
Post Thu May 05, 2011 1:40 pm
CHR1S1990 wrote:a little more info on his cam choice and we could be more accurate
Indeed, and a more accurate pressure value given that he states:
I’m assuming a gauge pressure of 250psi in my calculation given that’s where his gauge ended (the most accurate value he can give us). If the pressure was indeed higher then I would expect my estimate above to creep closer to the expected value.
CHR1S1990 wrote:but either way it seems his CR is around that of what it should be based on his piston choice and as you say, tuning is way off in this case. Sebastian you can rest assured you dont need to strip the block apart :cool:
For sure :thumb:
reggid
Post Sun May 08, 2011 9:54 am
E30 325is with M20B31
GeoffBob
Post Sun May 08, 2011 4:14 pm
GeoffBob
Post Sun May 08, 2011 6:32 pm
To add to the above, it is worth mentioning that calculating the CR of this engine is a purely academic exercise in any case (and one for which I must take the blame for raising). The probability of detonation occurring is a function of the combustion pressure and temperature and is thus only related to the CR of an engine in the sense that an excessively high CR can potentially result in an excessively high combustion pressure after the fuel/air mixture has been ignited. If the cam is chosen such that it results in a low dynamic CR, despite a high static CR, thus maintaining the combustion pressure below that beyond which detonation would occur, then the high static CR indicates effectively nothing. If, on the other hand, it results in an excessively high combustion pressure then delaying (retarding) the ignition timing will ignite the mixture at a time when some of the compression pressure has receded as the piston progressively moves past TDC. The question is thus, more specifically, one of whether a compression pressure of 250 psi is one that can be brought under control (prevented from exceeding the detonation limit during combustion) purely by means of effective tuning of the ignition timing. My gut feel, as a result of my very limited exposure to high compression Honda engines, is that this is indeed manageable, but requires a fair degree more attention to detail than say a low compression engine recording only 170psi that would indeed be considered less likely to ever experience detonation.
reggid
Post Mon May 09, 2011 4:19 am
GeoffBob
Post Mon May 09, 2011 8:30 am
reggid
Post Tue May 10, 2011 3:29 am
Sebastian35
Post Tue May 10, 2011 4:08 pm
I would just like to start with a big thank you guys! Away regularly with no net hence the random input. Now then I brought the cam from top end in the US along with Je pistons connected via m52 rods and m52 crank, sadly they must think I want a refund or something as I have no response from them! All I know I have some issues and not sure what direction to go in. A little info from them would have been nice. Correction parts will be brought else where nevertheless. Meanwhile i have Been playing with the miller chip and I have managed to get it running and should be able to gently run it in, Hopefully! timing has to be retarded somewhat and some v power fuel and tetra boost has helped pinging! Making 5 star is not where I want to be lol but I can at least run it in.
is there a way I can check cam profile? I have a dti gauge ect. I can say the profile was bigger than the standard, also a VE pulley is fitted but set to 0 Should I retard this to reduce the dynamic comp? As soon as I can I will invest in a good compression gauge and see what the compression of my warm engine is. If the cam is Wong can that really make the difference or is it just a power thing?
Thanks again all for you interest and help so far.
Sebastian35
Post Tue May 10, 2011 11:39 pm
Sebastian35
Post Tue May 10, 2011 11:41 pm
Sebastian35
Post Wed May 11, 2011 12:08 am
Sebastian35
Post Wed May 11, 2011 12:35 am
Seb here my gauge is 300psi and the engine was cold!
For sure :thumb:
