Glucklich's Cabby build from across the pond
glucklich21
Post Sun Apr 10, 2011 11:08 pm
Hello from the US! I figured since I lurk and come here to buy parts that we weren't blessed with on our shores, that you guys wouldn't mind seeing what I'm working on.
I don't know how to start this out, so I'll just post pics with a short description for now. What you're seeing is the work I've done over the past month.
Here's some specs:
1991 (10/90 build) M42 318ic Cabrio
AlpinweißII on Natur
I bought it last summer as a roller. No interior, drivetrain, etc
Donor car: 4/95 M3 with 70,000 miles (Our S50 is not your S50 hence this is in this section, it's just a 3.0 M50)
Engine pulled and on its way to its new home:
Home safe and sound:
New 323i flywheel to clear the oil pan
Valve cover off for inspection.
No gunk to speak of, chain is nice and tight, no wear on the sprockets, and no oil leaking past into the spark plug hole. :)
Record setting # of parts ordered from the dealership:
New starter and 413 EWS free ECU:
Started tearing down the engine.
Took off the intake to get the harness out.
Harness and hoses off:
Figured out how the hell to bolt up the manifold supports on my M50 while I was here:
Took off the thermostat and water pump out to find a nice discovery.
Thermo and water pump has been replaced! Not plastic!
Popped off the flywheel, flex plate, whatever.
Rear seal be leaking. :o
Put on the mount for the stand
Got to see if my M50 mount would work with only one bolt
Got it on the stand
AC Compressor off
Then started taking everything off of the other side
Date stamp
A complete 325i vert body harness down to the 13 button bits.
And untangled:
And some of the other things that came in that day:
And some of the contents:
Everything to refresh the tranny all in one bag:
Took the impact wrench to the engine. Got the harmonic balancer, exhaust manifolds, and the AC bracket off.
Also put back on the water pump and thermo housing to get it ready to be cleaned.
Had to figure out the studs
My reminder to drain the oil, pulled out the dip stick without thinking.
My G260 also came in, but the joy was short lived.
The Carr Industries headers:
AKG Poly swap mounts:
Random parts from Turner, mainly delrin bushings for the shifter and stainless clutch line.
E34 oil pan, pump, and pick up.
Bought a Soda Blaster to clean parts:
Here's the engine before a thorough cleaning with some purple power:
For the most part clean, still had a few spots left courtesy of the oil filter housing which got removed.
And the opening taped up:
The next day started with painting.
While the paint finished curing, I decided to start replacing some things.
Before and after:
The Spec Stage 2 clutch came in:
Then I decided to use my new favorite tool. A bitch to load tho.
Before:
After:
Those aren't new bolts. :)
Since the oil filter housing is nice and purty, I decided to start some reassembly.
New gasket:
Thread locked and torqued accordingly:
New oil pressure sensor:
New oil supply hose and hardware:
New filter kit with a matching new filter housing bolt:
Next I put the valve cover back on with some plastic wrap on it to stop some soda residue from entering the engine. (Still not done)
Flipped the engine over and started removing the bizzion oil pan bolts.
Took out the baffles, support bracket, replaced the pick up seal, pump nut torqued, red loctited, flattened the threads (it ain't going anywhere), and installed the E34 pick up.
The gasket was missing in my box of parts, so I should have that by Thursday. (It was ordered and paid for, but they just forgot it)
How she looked after that day:
Fast forward to today:
Driveshaft and linkage came in:
Installed the rear headers:
Got a new blaster, old one's regulator blew up, yay for warranties!
Put the AC bracket and pulley back on.
Finished up the headers:
This kit gives you 2 extra normal nuts for securing the studs:
And painted and installed some of the things that got blasted.
Not new hardware either....
And here is how it stands tonight. Still a lot more to do, but I can see the light.
Installed the water pump. I know it's been in pics, but I hadn't actually installed it all the way yet, it was just there for mocking up.
Then moved onto the thermostat housing and 75 degree thermostat.
New hardware for this:
I then removed the trigger sensor. I'm planning on soda blasting the front as you can see where coolant leaked for awhile, so it's a little discolored. I'll have to take off a few things on the front, but it will be worth it. :)
Also took out the spark plugs, didn't look too bad. There's some water on them from cleaning the block. Thought I got it all. :rolleyes:
They will be replaced down the road
New wire guide and c clips for the trigger sensor.
Another pic of the headers, can't stop looking at them.
New ground cable from NOKE325.
Soda blasted and painted some things over the past few days. New hardware and gaskets for the valve cover. (also got blasted) I found the OEM gasket has a metal center, unlike the aftermarket one I have on my M50 that's nothing but rubber.
Here's a peek of the engine bay. I have a lot of work to do over the next few days to get it ready for paint by the end of the week.
Also prepped the front to get blasted, as well as the oil pan. (took out the bolts)
Got a new intake at the yard today.
A glimpse at the interior. Its a combo of all kinds of colors.
The interior is a mess. It will be the last stage of the project. Stages follow like this:
I. Drivetrain
II. Suspension and Braking
III. Exterior work
IV. Interior
Thanks for looking. ;)
Looking for M-tech interior and intensive wash bits PM me
Post Sun Apr 10, 2011 11:17 pm
Epic mate, keep the updates coming :cool:
glucklich21
Post Mon Apr 11, 2011 7:37 am
Today I decided to clean the garage a bit, it was getting ridiculous.
The S50 outside:
Kinda done, it was getting late and I was just happy I could get my E30 in the garage.
Oh and I hope everyone likes the pics, I had to upgrade my hosting account, everyone is eating my bandwidths! :mad:
Alpina99
Post Mon Apr 11, 2011 7:59 am
Absolutely fantastic,
Your attention to detail is excellent,
Keep the updates coming, this is great !
Gone, but not forgotten !!
Supafly
Post Mon Apr 11, 2011 2:21 pm
Great to see the progress, and detailed pics are always useful :)
glucklich21
Post Mon Apr 11, 2011 3:23 pm
Thanks guys. :)
glucklich21
Post Wed Apr 13, 2011 8:28 am
Since I didn't feel like getting covered in soda and I didn't feel like sweating in the garage today, I decided to work on the new body harness instead.
The new harness is out of a 1991 325ic with a build date of 11/90 or so the date stamp on the various looms say.
It at some point had what looks like an alarm system or something. So I started repairing.
But I did print this out first to help. Sectioned and labeled at that. :)
1992 as it was pretty definite as to how everything should be, all design problems sorted by then.
Lots of these:
Removed:
Soldered back together and shrink wrapped.
More
Looky there more!
I don't even know about this part:
WTF is this even?!
Next up was the airbag stuff. FYI I did write down all of the splice #s and locations if you want to completely remove it from your harness. LMK if you want a step by step.
SRS fault light in the check panel:
In the main power splice:
Switched power splice:
But after a while I got it all out.
And continued fixing things here and there. Quite a few snipped wires I wasn't aware of.
If anyone needs to know what a particular harness or section looks like, now is the time for questions before it get rewrapped in a few days. ;)
Also anyone know a source for the european version of the electric troubleshooting manual? I would like to retrofit a few things.
glucklich21
Post Thu Apr 14, 2011 7:37 am
This afternoon I started tackling the engine bay, the goal is to have it on its way to the paint shop either Friday or Monday.
Kinda got caught up in the moment, so pics are a bit lacking in terms of flow.
Here's what I started with.
First task was to remove the harness the best I could for the time being. I can't completely take it out till I pull the interior. (Hopefully happen tomorrow)
I got the passenger side out, but still had the ABS module in place. To unplug the harness from it, you need a T-15 torx bit. There's one screw on top, and 2 under the cover that hold a wire retainer in place.
The actual lines themselves require a 11mm wrench. So I decided now was as good as time as ever to tackle the brake/clutch lines. Somehow got lucky and no problems, aka nothing stripped or required flare wrenches! :D
ABS unit out, it has 2 10mm and 1 13mm nuts holding it physically in place, in addition to a 8mm nut that attaches a ground cable to G104. Note the rubber bushings.
Next I took care of the fuel lines. I'm not totally taking them out because I'm not worried about overspray. They're getting replaced since about 4in down the line, there's a section taken out because the PO was running OBD2 in this car that required a secondary fuel pump. That big cylinder thing goes to the rear brakes. I believe it is what actually controls the bias.
Then it was time for the insulation. Since mine is in good shape, I decided to keep it, so a little more work was required so it wouldn't tear. Lots of nuts and retainers keeping this thing on. The steering column was also in the way, but 2 bolts and nuts the rack is free and I just pulled the spindle out of the column with the e36 rack.
Yay no rust! (Honestly shouldn't be any on this car since it was a Cali, then Texas car it's whole life)
Part of the harness was trapped because of the valence. Luckily I had forgotten I had fitted it with zip ties to mock up mounting for the Alpina valence, so that came off in 1 minute flat after the lights/grills were removed.
By this point you can get a good look of the repair done to the core support because of the small accident that landed it in the PO's hands. He did a good job fixing it, but some welds need to be touched up and grinded.
13 button exterior harness out.
Throttle cable/brake hoses, etc out
Time for the fenders.
Yay no rust either, just some surface and left over body seam filler.
Took the horns out, note the difference in the OBC horn, it's flat and has no "trumpet" opening.
Then the stickers.
Look at how thick the Cosmoline is. You can actually feel the thickness of it by running your finger over where the sticker was and the strut tower.
Unbolted the fuse box and tied up the harness.
Took car of the AC lines and the other few things left in the bay.
And here's what we have left:
glucklich21
Post Fri Apr 15, 2011 8:19 am
Lots accomplished in the 6 hours I worked on the car.
The plan was to get the interior out.
But first need to clean it up. :X
My $10 rear seat.
That's better:
Rear seat out
Some column stuff off and out
WIRES!
Left is the where the dash harness connects. Things like hazards, flashlight charger, etc. Right is the C302, this is where accessories plug in for power.
Dash out!
I felt like an idiot once I figured out how this came apart.
And then my phone died. So pics pretty much show the end result.
"BUT WHERE'S THE HARNESS????!!!!
Here it is!
Shit is long
Made this:
Each individual section zip tied to it's self then tied up.
Cloth tape shedding everywhere.
Called it a night :)
Supafly
Post Sat Apr 16, 2011 1:31 am
Doing well, keep up the good work and thanks again for the detailed pictures. They make for interesting viewing now and in the future I'm sure many people who are stuck will use these as references.
glucklich21
Post Sat Apr 16, 2011 6:24 am
I've been known to use other's threads as a point of reference, particularly when I was building my M50 for my MT-2 4 door. It was out of an E34 so naturally the old engine arms were in a different location. With the E36 arms on I couldn't figure out where exactly they were suppose to go. Skimming through someone's thread I found my answer. :)
glucklich21
Post Tue Apr 19, 2011 7:40 am
Helped my dad build a fence so it stayed like this a few more days:
Starting soldiering stuff onto the new harness on Sunday. When I soldiered the window breaker switch wires together I decided it time to go to bed.
Today I wanted to soda blast the remaining stuff so I can start reassembly. And did so. All the remaining bolts, oil pan, and timing case.
Oil pan before:
After:
Timing case after. (No "real" before pic just no more grim and stains)
New work light allowed me to continue past dark. :)
Vanos solenoid blasted twice, 1 failed paint attempt, and started fresh with a coat of etching primer.
Then a high performance enamel like the other black metal pieces. *still drying in picture
Blasted the engine hoist bracket I got from the yard as I was missing mine. :(
Finish line I can see you. :)
glucklich21
Post Thu Apr 21, 2011 4:52 am
Looking for some parts guys.
LMK if you have any of these:
http://www.e30zone.net/modules.php?name ... c&t=195851
Update coming later tonight. :)
glucklich21
Post Fri Apr 22, 2011 8:08 am
I'll do a big update when I'm done with the wiring. So far I'm adding this to the harness:
"Euro" side markers that stay lit and blink- I don't have these period since I have a US spec E30
One button control that puts all of the windows down or up at once. -Still need the cabrio electric top up and down switch tho.
16 guage wiring for a future audio install
Foot well lighting like in my other E30
Extra trunk lighting
Rear fog light
Switched/constant positive and neg leads in the center console, glovebox, and under the dash for future accessory installs if necessary.
Hardwired radar power supply
And some other things I'm sure I'll come up with. :rolleyes:
For now though, I have a mini update.
I took the engine off of the stand so I could get started on the rear, but did some other things first.
Close up of the painted brackets, so purty. :)
Installed the vanos oil solenoid.
New hardware for the trigger sensor:
The junkyard hoist bracket installed with new hardware:
Next I wanted to prime the valve cover for paint, at the time I hadn't decided on a color just yet.
Taped up:
Finished product:
And for shits and giggles, My LCI M-tech 335i E90 and my M-Tech II E30. :)
glucklich21
Post Wed Apr 27, 2011 9:21 am
So I'm borrowing this for a few days, been bro-ing so hard....
Pulled the cabrio out of this garage for the last time. (that house has been sold)
Rented a U-Haul and loaded it up.
Vacuumed out all of the loose harness wrapping.
And took it to the car wash to wash the bay and the body. It hasn't had one in at least 3 years.
Dropping it off tomorrow to get the bay painted. :)
mr_dink
Post Wed Apr 27, 2011 9:32 am
wow you really don't cut corners mate!
Is that a brand new ECU? How much was that if you don't mind me asking?
glucklich21
Post Wed Apr 27, 2011 9:45 am
mr_dink wrote:wow you really don't cut corners mate!
I've put too much into this project to cut them. :)
I haven't bought a new ECU, which pic were you referring to?
glucklich21
Post Wed Apr 27, 2011 9:27 pm
Dropped off at the paint shop. :)
glucklich21
Post Tue May 03, 2011 10:27 am
So I haven't done too much lately. Been busy with getting the M42 out of the M-tec. But it's not like there's much more to do.
Got that out and realized I need more room.....
Moved on to 21.5# injectors installed. They still need to be rebuilt, but I'm going to run them in their current state for awhile till all of the possible crap is out of the fuel system and engine.
New fuel line with BMW clamps
The whole intake unit
Put in a new OEM E34 M50 spider hose. It's slightly different
then the S50's.
New clamps as well
Used a random coolant hose for the now deleted throttle body heater valve. It will now connect to the left side of the throttle body and coolant will come out the left side to the spider hose.
Smeared JB Weld on the imperfections on the valve cover.
Sanded, high temp primered, sanded, high temp primered, and finished off with a high performance, high gloss enamel. More on this later. Also installed the engine harness at this point.
Hooked up an old stereo to some crappy speakers out of the old E34 parts car, even has an auxiliary in for my iPod. :)
Next up was the 323i flywheel and Spec stage 2 clutch. Had to clean the anticorrosion crap off of the fly first tho. That stuff is thick and sticky.
All cleaned up
New fly bolts
Installed the wrong bearing. -_-
Left is the e30 (12mm) , right is the M/S5X (15mm). You want the E30 one if you're using the E30 transmission.
Any who got the fly on.
And test fitted the clutch
The replacement tranny came in today, upside down, on it's side....
But no damage this time around, so it's okay!
glucklich21
Post Wed May 04, 2011 7:56 am
Here's another mini update
I had done this back on the 23rd, but never downloaded it off of my phone.
Rear crank housing and rear crank seal.
When I first started pulling apart the engine, this was one of the first things I noticed, how badly it was leaking.
Housing popped off
You can see where it was leaking from behind
Old seal out
New stuff
New seal installed
New gasket
Everything buttoned up
I had also test fitted the fly at the time, you can see the advantage of the 323i flywheel, it clears everything with no shaving required.
Also replaced the o-ring for the fuel pressure regulator at that time as well.
Alright today's accomplishments
Output flange off
Tried to drain the fluid, but was already done. Note the magnetic plug.
Moved on to the bell housing, the best I can tell the seals were replaced. So we shall see. I'm still going to replace the rear and shifter seal since they are easy to replace.
Installed the new hardware
New pivot arm and spring
Vin of the donor car, I'll be running a carfax to see if I can get a clue on the mileage.
SS Clutch line and new slave
Cap put on to keep crap out for the time being
Lifted the S50 up and put it on a dolly to help with the trans fitting tomorrow
Rearranged the engines since the cabrio will be ready tomorrow and I can't leave it outside. :)
Moved on to popping out the S50 pilot bearing to install the E30 pilot bearing. I used wet newspaper, the clutch tool, and a heavy hammer.
Tada!
The remains
S50 left, E30 right
Drove in the right bearing with a 7/8" impact socket, it's a perfect fit
End result
glucklich21
Post Sat May 07, 2011 9:45 am
I'll do an update later, but a pic for now.
randomspeedfreak
Post Sat May 07, 2011 4:23 pm
lovin this build!
Post Sat May 07, 2011 4:59 pm
Epic!!! :cool: :cool:
glucklich21
Post Mon May 09, 2011 9:53 am
Thanks! :)
I'll give a teaser of this weekend's progress.
