m52 cams
randomspeedfreak
Post Thu May 05, 2011 4:42 pm
whats the deal with cams and vanos on an m52?
no go or dosent matter?
(edit: 'dosent matter' as in most cams are fine with vanos)
Post Thu May 05, 2011 10:07 pm
What are you asking here?
Can you fit hot cams to a M52?
randomspeedfreak
Post Thu May 05, 2011 10:19 pm
E30BeemerLad wrote:What are you asking here?
yes that
Post Thu May 05, 2011 10:21 pm
You want S52 cams then, these are only found on the US E36 M3, it's basically a hot 3ltr M50 with cams.
£350 is usually the going rate for a used pair
randomspeedfreak
Post Fri May 06, 2011 11:18 am
ok.
no option for schrick cams then?
cheers
Post Fri May 06, 2011 11:24 am
Probably is, but I would guess you won't see change from £1k+ for a pair of schrick cams
randomspeedfreak
Post Fri May 06, 2011 12:27 pm
E30BeemerLad wrote:Probably is, but I would guess you won't see change from £1k+ for a pair of schrick cams
fuck a duck!
how rare are m3 cams?
know anything about m50b25 pistons in a 2.8? read somewhere can get a mad compression ratio
thanks for your help so far
Post Fri May 06, 2011 12:44 pm
Engine internals, I know nothing about. Dan is probably the person to ask about this.
The M3 cams are available, need to look on ebay.com (USA site) and they are there.
Dezzy had a contact somewhere bizarre like Lithuania who he had got a pair from in his 3ltr hybrid M52 donk
randomspeedfreak
Post Fri May 06, 2011 6:45 pm
E30BeemerLad wrote:Engine internals, I know nothing about. Dan is probably the person to ask about this.
ok sure im off to have another look at dezzys thread
cheers bro
