E21 brake servo
Sjoerd320i
Post Wed May 04, 2011 10:50 am
Hi lads,
I have just purchased an early E21 brake servo which is supposed to be the smallest one available.
My question is to what length do I have to shorten the rod so it will fit my e30
bimanut
Post Wed May 04, 2011 6:37 pm
Technology has come on a long way since the E21, would have gone for the clio one (which is german after all).
The rod sits flush with edge of the servo on an E30.So which ever you use it has to be the same. :)
Sjoerd320i
Post Wed May 04, 2011 11:26 pm
Can't imagine that they evolved that much because it aint exactly sophisticated engineering.
So maybe I have to push the pedal a bit harder but can't really be bothered about that.
e21Jason
Post Wed May 04, 2011 11:31 pm
the e21 servo conversion is a LHD thing not sure many people will of done it here
Jason
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
bimanut
Post Thu May 05, 2011 5:57 pm
I maybe stood corrected but a clio servo has a double diaphram,therfore should be better pressure?
