Specialist Components S54 gear
Post Tue May 03, 2011 10:13 pm
Anybody used or know of a user of this ECU/loom adaption? Looking at using one and would like some feedback from other users
ajay
Post Wed May 04, 2011 7:16 pm
I have spoke to them a while back whilst deciding to go down the s54 route myself.They seem pretty confident about their product and reqire your engine loom which they modify and return to you with a new ecu and wiring diagram.I think they can also supply a cable throttle conversion kit or youcan get one from ca automotive,i have heard that ian haynes does the engraving on their ecu,s.maybe he would have more insight into their kit.
glenn
Engine Transplant Services
Post Wed May 04, 2011 7:18 pm
DanThe wrote:Anybody used or know of a user of this ECU/loom adaption? Looking at using one and would like some feedback from other users
what have you got planned dan?
Post Wed May 04, 2011 7:43 pm
Its not for one of my cars, ive spoke to them on the phone and it sounds good for the money, just interested to hear from anybody thats used it
ian332isport
Post Wed May 04, 2011 8:32 pm
ajay wrote:i have heard that ian haynes does the engraving on their ecu,s.maybe he would have more insight into their kit.
Fraid not :D
We just supply the aluminium enclosure that they put them in.
If anyone is interested, you can see more of our boxes here:
http://www.lincolnbinns.com
and here:
http://www.panel-print.com
I do all the design and 3D modelling as well.
Ian.
Post Wed May 04, 2011 8:51 pm
Well at least we know the case will be up to the job :D
GermanGorilla
Post Sun May 08, 2011 11:31 am
Hi,
I have a colleague who is using
this set up on a E46 M3 GTR Race car.
S54 Engine with Drenth 6 speed Seq box.
They run it in conjunction with a AIM
Dash which was a simple 2 wire connection,
and have some higher lift cams etc, which
required additional mapping.
His feed back is that its a very good system
and very user friendly if you want to alter
the std map etc for engine modifications.
Easy to fit, about 5 or 6 wires as its basically
a re-configured S54 engine harness adapted
to their ECU.
Its big advantage is that for a Road focused
car it retains the Vanos.
Try finding anybody to fit and map A.N. other ECU
and retain the S54 Vanos. Then ask the price.
As a tail note, Kohler Racing in Sweden also
sell these, and I believe have used them,
so given their Racing reputation it speaks
for itself.
Std Siemans MS S54 ECU is good, CSL version is
better, but if you want to make your own configurations
then for money you will struggle to find a proven
product at such good valve.
I have no association with them.
Regards,
The Gorilla.
Post Sun May 08, 2011 1:03 pm
Thanks for that :D
The guy told me they are very easy to map should it require it 8)
