A couple of hours later:
You want to speak to meatballs82 on here mate, the KWP was about £30 plus vat, a very good price tbhmaf260 wrote:That seems to make sense, thanks.
Water pump from main stealer or GSF/ECP?
Not quite! the spigot bearings changed in the m42 etc in sept '90, can't remember the sizes at the mo, but I remember when i changed the engine in my 318iS I had to change the spigot bearing because I was using a slightly different year engine.e30-dk wrote:For example- m40 or m42 box = m20 spigot bearing (12mm hole)
