It didn't have the problem in the donor car, and everything has stayed the same. Inlet hasn't been off either.
So far I've cleaned the maf with electrical contact cleaner as it has a cone filter, checked for air leaks with carb cleaner around the inlet pipes, t/b, inlet manifold. Checked wiring connectors by injectors(lambda), exhaust manifold(twist connector for coils?), afm, t/b, fuel evap valve.
I've just ordered a set of plugs and I've been sent out four! this was after confirming that it is a six cylinder. I was planning on giving up for the day... but I just can't. Sent a mate out to get me another two plugs and planning on changing them to see if it makes a difference, although as nothing has changed I can't see why there should be a problem but for the sake of a set of plugs I thought why not.
If anyone has any ideas on what else to check or if there are any common causes I would really appreciate any pointers
