Yah thats it, Please list down the complete list of symptoms when an AFM in an E30 325i is no longer working properly.
Much apprecited.
When the O2 sensor begins to wear out, you may notice the car runs a bit sluggish, fuel economy may be down, and in sometimes, it may cause an annoying intermittent surging idle problem, (as was the case on my car). Once I replaced the O2 sensor, I noticed a increase in gas mileage as well as a mid-range increase in power and drivability.
Unless you're not in the UK, or have a late E30 with all the emissions stuff, then no relevance at all, since you don't have an O2 sensor.haffeel wrote:Guys check this out
http://www.pelicanparts.com/BMW/techart ... Sensor.htm
Is that article relavant to my problem?
AFM does nothing much at idle, since the flap is just about on it's stop, and the TPS switches the ECU to th idle settings. The air bypass screw on the AFM is used to adjust CO level at idle, which is import6ant to getting your car through an MOT test.haffeel wrote:Guys, can any one confirm this. I was speaking to a guy, and I was told, there is nothing much to gain from tweeking the AFM. such as adjusting the CO2 etc.,
reason
AFM CO2 adjustment is valid only for when the car is idle, during normal run AFM has no function. How true is this
