where does it go
it's much bigger than any of the ones in the pic ^^^
gonna check that out nowCook318IS wrote:Its a dual layer pcb ecu. You need to remove that pcb board and the chip is on the layer below
E30BeemerLad wrote:What's happening Mick, not fast enough already?
craigieeb wrote:You'll need it
I'm laughing then as I have a non vanos.e30-dk wrote:His is a non vanos engine so I'm guessing he got it from maurice (speedtouch), he does them for around £30 posted and the feedback on all his chips is great!
He hasn't got 1 available for the vanos version yet though, which I was gutted about but if you have a non vanos m50 your laughing. Drop him a pm
Where in south Wales are you mate?e30-dk wrote:![]()
Ah I'm not to far from you I'm only in merthyre30-dk wrote:I'm in barry mate
Yep I'm always up for a BMW meet mate. Mines an e36 325 not an e30 thoe30-dk wrote:Aw kool, nice to know there are others local man. We should see how many others are local and have a summer meet
it's now fitted to the car and working well,rev limiter is up to 7.5k rpm now and seems a bit more responsiveSpeedtouch wrote:magpie, you may want to check that the 403 ECU works with this chip, as it's intended for a 405 ECU.
Who?Speedtouch wrote:Which ECU are you using?
7.5k is abit dangerous on these isnt it? I thought it was safe to only rev to a max of around 7.2k?magpie wrote:it's now fitted to the car and working well,rev limiter is up to 7.5k rpm now and seems a bit more responsiveSpeedtouch wrote:magpie, you may want to check that the 403 ECU works with this chip, as it's intended for a 405 ECU.
You. And what chip does it have in it?craigieeb wrote:Who?Speedtouch wrote:Which ECU are you using?
lol
