This is how it looked when I got it, I’d took a few bits off before this pic was taken (like the front mani) but obviously it needed a little tlc.
I dropped a few bits out the way so I could get to the engine block, not going to go mad because I would like to get the thing in the car and once you start with these things you end up down to every last nut and bolt etc and unfortunately I just don’t have the time for it!
Got myself an engine stand and mounted it up, wasn’t till I started I realised I was a bolt missing in the bag of bits to mount it so 3 would have to do lol
This is what the block looked like:
And this is inlet side after a bit of a clean and coated in engine block enamel...
Got a long way to go but slow progress is progress none the less
