noises and vibrating?
abeazer
Sat Apr 09, 2011 10:58 am
right the other day my car started to rumble and judder a bit around 2000rpm and my gearknob would vibrate, then i was driving along in 5th and the gear shift linkage came off at the gearbox end and i had to find my way home in 5th. put it back on and my car seemed to be a bit better but now its just doing the same? the noise is worth when its in 5th?
thanks aiden
abeazer
Sun Apr 10, 2011 11:47 am
anyone?
m_jermyn
Sun Apr 10, 2011 3:07 pm
Need more info...
Where is the vibrations coming from Front rear middle of the car?
Does it lose power?
Does it cough and spluter?
abeazer
Mon Apr 11, 2011 3:09 pm
erm middle and rear
it doesnt loose power or cough or splutter, it feels like the gear shift linkagew is hitting the prop?
abeazer
Tue Apr 12, 2011 5:25 pm
suggestions?
schnaarf
Tue Apr 12, 2011 5:53 pm
A stab in the dark but.... has yours been fitted with a short shift at any time?
If so, the linkage between the shifter and the g'box can be very close to the prop which is why a slight bend in this linkage is necessary.
It may be that your prop bearing or guibo is starting to wear out and the extra movement in the prop has caused it to start hitting the linkage...
See the last two pictures on this page:
http://www.e30zone.net/e30zonewiki/inde ... conversion
abeazer
Wed Apr 13, 2011 6:20 pm
it hasnt had a short shifter fitted at anypoint
how could i test the prop bearings?
could i make a 318i prop fit?
cheers
mrLEE30
Wed Apr 13, 2011 6:26 pm
Also sounds like your rubber donut bushing failing, you need to get underneath and remove the exhaust heat shield and give the prop a wiggle and check the donut - in between prop and gearbox - if it has bits of rubber missing then replace, requires exhaust partially off, no need to change the prop, just be careful when you split it to put back in same spline. Also worth to change centre bearing while it's up and exhaust is off.
abeazer
Sat Apr 16, 2011 10:41 am
yeh ill get under it and have a look, would a 318i prop fit?
mrLEE30
Sat Apr 16, 2011 12:14 pm
On a 318 yes. Would help if you mentioned what you have and us it auto ?
m_jermyn
Sat Apr 16, 2011 3:28 pm
Or even the gearbox mounts might be on there way out.
abeazer
Sat Apr 16, 2011 5:54 pm
its a 325 manual and the gearbox mounts looked ok i checked them last week when i put the linkage back on
mrLEE30
Sat Apr 16, 2011 7:12 pm
318 prop wil not fit at you have the 260box and 6 cylinders.
you need a 325 prop (i think even the 320 wil not fit due to the 320 having the 240 box - but could be worng on this)
m_jermyn
Sun Apr 17, 2011 1:24 am
abeazer wrote:its a 325 manual and the gearbox mounts looked ok i checked them last week when i put the linkage back on
Hang on a minute so this all started after you did some work on the car? I suggest you go over what you did and double check everything you did.
