Has anyone any experience using arp fasteners on an m50 for the main bearing caps?
My problem is that the studs dont seem long enough to fully screw them into the block and leave sufficient thread at the other end for the washer and nut i.e. the nut is proud of the stud.
m50 arp main studs
baptie0
Aston-AKA-Ash
Haven't experience with them but i'd give ARP a ring and double check what you've got against what you should have, i'd expect the thread to protrude from the nut at least a couple mm's for peace of mind.
Just here for research for now.
E30 project will start early 2012 after Mk4 XR3i cab resto-mod project is finished.
