e36 m42
zimmerkid
Thu Apr 14, 2011 12:13 am
How many people are running the e36 m42 engine in their e30's??
and how many of you run lambda sensors and how many dont? what sort of mpg do your m42's return?
Im trying to get to the bottom of my M42 not running properly, before i resort to another swap!
Its running with the e36 ecu and engine, an e30 engine wiring loom, e30 inlet manifold and exhaust manifold.
Thanks in advance!
Bandit400
Thu Apr 14, 2011 10:23 am
Hi,
I'm running an e36 m42 with e36 intake, ecu and lambda sensor. I get around 35-40 mpg.
zimmerkid
Fri Apr 15, 2011 12:52 am
Thanks for the reply, Im wondering how much difference to performance and economy it would make running mine with lambda, I only get about 30mpg at a real push
Bandit400
Sat Apr 16, 2011 7:03 pm
Without lambda sensor your engine will default to a rich setting this inturn will make you use more fuel. You will also lose some performance. Hope this helps.
zimmerkid
Sun Apr 17, 2011 11:45 pm
That confirms my suspicions! Think I'll be looking for a lambda sensor then :)
Hibsfan1875
Sat Apr 30, 2011 4:26 pm
Does the engine still go into limp moade if the air intake system and ecu from
an e30 m42 is used?
Pre-mature ejaculation society dinner this friday night. No dress code, just come in your pants
Sat Apr 30, 2011 9:19 pm
i have a couple of e30 318is ecu's here if needed
balilu91
Mon May 02, 2011 3:05 pm
zimmerkid did you ever get to install a lambda sensor? and what benefits did you get? coz im in the same situation aswell. and it has to be the "factory like" sensor or will and other car lambda sensor do?
Matt_M44is
Thu May 05, 2011 11:21 pm
I only get 30 mpg from my m44 controlled by m42 ecu.
