Intake Intake cams
emdog16
I have been doing some reading, Has anyone run 2 NV m50 intake cams before?
Avid E30 Nut, and Scientist of all things that go BOiiiNGGGG.
If you want to go mental on your shocks... check out ForRacingUseOnly.com
On what?
You can use a Non Vanos intake cam as a 'performance' exhaust cam but you will still need a higher lift/duration intake cam to get any benefits
emdog16
Im thinking using an intake cam as an exhaust cam is really only optimal for a turbo setup. Never mind...
