What I have to do when it won't start is bridge the fuel pump relay live and then it will start and I can remove the wire.
I changed the blue temp sensor for a new one as well as crank sensor. Dizzy and rotor arm are like a month or two old.
Sometimes when it starts it will misfire and provide black smoke.
When idling from cold sometimes it will sit at 1000revs then when it warms idle at 500 causing it to nearly stall. Sometimes it starts up from cold and stays on 500 revs.
Any ideas or suggestions as this is a massive arse ache now
