New project m52 touring
gudgeon
Post Tue Mar 29, 2011 11:44 am
Haven't read the whole thread but will make a couple of pointers.
On my M50 the bit sticking out from the airbox is a thermostat controlling hot water circulation to the throttle body. I won't be plumbing mine in.
The only reason you'd get a difference in revs when removing the oil cap is if the crank breather pipe is connected to the inlet. If this is blanked off at the inlet then no air is entering at this point even when the engine inside is open to outside air.
shedrool83
Post Tue Mar 29, 2011 8:01 pm
Jozi wrote:Just had a look there, whats the thing that sticks out from the airbox?
Your going to have to update your signature now :) What other 24v tourings are there now?
Havent a clue what the bit sticking out the side does.
I still have the m30 touring so no need to update just yet .
Jozi
Post Tue Mar 29, 2011 8:03 pm
I had no idea you had two tourings! I have one with an m52 that doesn't run and the other is currently on a spit :P
shedrool83
Post Tue Mar 29, 2011 8:08 pm
gudgeon wrote:Haven't read the whole thread but will make a couple of pointers.
My crank breather is connected to the t/b rubber boot,so the revs should alter ?
Tried carb cleaner tonght an found nothing .
I'm still having issues with the coolant .The heaters are cold and the water doesnt seem to be circulating through the wee hole at the top of the rad (under the cap)
Post Tue Mar 29, 2011 8:17 pm
Squeeze the top hose top push the coolant round, have youbtaken the bleed screw out? are the heater pipes on the right way round? Back of head to bottom pipe on bulkhead
shedrool83
Post Tue Mar 29, 2011 8:24 pm
I have been opening and closing the bled nipple periodicaly . I did he it out and running and i wasnt getting anything (water or air)
Positive the hoses are on the right way.
The fan is coming on at the 1/2 way mark and going off about 2 niddle widths below it.
gudgeon
Post Wed Mar 30, 2011 9:42 am
shedrool83 wrote: My crank breather is connected to the t/b rubber boot,so the revs should alter ?
Yep, but it might be worth just blanking off the inlet boot while you troubleshoot.
I'll be doing this on mine, it'll also let you know how much blow-by is coming out of the engine.
shedrool83
Post Fri Apr 08, 2011 6:50 pm
Brought it up the road tonight and i have to say 3rd gear is my fav.Pulls like a train and does put a smile on your face.
Need to get the standard suspension off asap and the cup kit on also need the tracking done .
Still have a small niggle of the revs taking about a minute to drop from aroud 2k to 600 when started from cold tho :cry:
nickso
Post Sat Apr 09, 2011 12:45 am
shedrool83 wrote: Still have a small niggle of the revs taking about a minute to drop from aroud 2k to 600 when started from cold tho :cry:
thrash it until it's warm then. :twisted:
'88 e30 328i M52 track bint.
shedrool83
Post Sat Apr 09, 2011 6:47 am
:cool: :lol:
nickso
Post Sat Apr 09, 2011 11:08 am
on a side note i can't wait to see what the difference is between my lightweight turd and your fully optioned touring. should be interesting.
Post Sat Apr 09, 2011 1:39 pm
Have you got a weight for yours Nick? Manifolds will be on their way Monday BTW
The cold idle seems to get better the more you run the car Jake, if it really gets on your nerves try a few different ICV's
shedrool83
Post Sat Apr 09, 2011 2:42 pm
Will leave it for now and see how it goes then Dan.
Hopefully find out at a meet soon Nick :D
nickso
Post Sat Apr 09, 2011 3:17 pm
DanThe wrote:Have you got a weight for yours Nick? Manifolds will be on their way Monday BTW
not had it weighed dan, not really sure where to get it done round here. not even got a guess, slightly over a ton i suppose.
cool about the manifolds, just needs the exhaust putting back on, the rear dampers and doors putting back on and it's ready to go for another summer :D
much fettling to happen over the summer of course.
Post Sat Apr 09, 2011 5:47 pm
No builders merchants? They will have an accurate weigh bridge
shedrool83
Post Sat Apr 09, 2011 5:57 pm
Scrapyards have them to Nick .
nickso
Post Sun Apr 10, 2011 2:00 pm
can't take into scrappy as the place is a mud bowl. builders merchants is a possibility.
shedrool83
Post Fri Apr 15, 2011 12:18 pm
Just wanted to say ,i have had this on a wee run of mixed roads today after getting the tracking done this morning.
I have to say feck me its quick.
Came off the circle onto the dueller in second @20ish .Foot down upto 60 in no time changed to 3rd upto 90 rapid stuck it in 5th and slowed to 70 .Well impressed :D
Driving the country roads were just as good (the reps did spoil it abit an need to go)The car handles really well and the e36 rack makes a huge difference imo.
I would recommend this swap to anyone .I had a 235bph classic wrx/sti as a daily before i decided to sell it and start this project .And it was quick (if you got you gear changes right )but i honestly think this is quicker it just pulls like a train :D
As always with e30's there is still bit i want doing but for the moment i'm just going to use it. So will still be adding to the thread.
Awesome totally loving it.
Thanks for all the help along the way and a special thanks to Dan for making this conversion easy with his loom,manifolds etc.
nickso
Post Fri Apr 15, 2011 7:02 pm
oh dear, hope it's not quicker than mine. :)
problem with scooby's is you have to keep changing gear, the 540 would wipe most scooby's because it would do in one gear what a scoob needed two to do. i would say my m52 is quicker than the 540 and it kept up with ritchies m5 not too badly at all.
roll on our little drag race. :twisted:
shedrool83
Post Fri Apr 15, 2011 9:03 pm
Crails on this Sunday Nick winkeye or do you still have bits and bobs to do?
nickso
Post Fri Apr 15, 2011 11:44 pm
haha bits and bobs! it is far from done mate. no fluids, exhaust is feckin miles out, rad is pissing coolant and it has no doors on yet.....don't think i'll make it mate. :(
would have won anyway so lets call it a cirrus victory. :P
shedrool83
Post Sat Apr 16, 2011 7:44 am
Ha ha
I'd expect you to win due to wieght tbh but it still would of been a giggle.
I'm sure Gaz will have a rad that will fit if your not going for a new one.
nickso
Post Sat Apr 16, 2011 11:42 pm
i have a new rad sitting in the hall but the wiring thing is holding me back, i need a resistor doofer.
