New project m52 touring
Post Wed Mar 09, 2011 8:46 pm
Those manifolds & downpipes are the shizzle.
TBH, if it wasn't for the shallow rear panel on chromies I would be rocking a standard system. Too much guts on display at the rear with stock silencer
shedrool83
Post Thu Mar 10, 2011 4:27 pm
Final parts arrived today :D
I say final but I still want to renew the suspension shocks and springs soon.
Just dont know what to go for atm.I'm thinking H&R cupkit or Gaz coilovers but will have to save up more pennys first. :(
nickso
Post Thu Mar 10, 2011 6:20 pm
i have my cup kit for sale jake, probably done less than 2000 miles and are as new. springs should be ok for the touring too but you may want to check on the differences between the rear springs on tourings/2 doors. comes with new front top mounts that have done the same mileage. no hurry to sell so if we agree on a price you can have them until you get the money together or i will keep them for you if you want to wait until first meet.
'88 e30 328i M52 track bint.
shedrool83
Post Thu Mar 10, 2011 6:25 pm
nickso wrote:i have my cup kit for sale jake, probably done less than 2000 miles and are as new. springs should be ok for the touring too but you may want to check on the differences between the rear springs on tourings/2 doors. comes with new front top mounts that have done the same mileage. no hurry to sell so if we agree on a price you can have them until you get the money together or i will keep them for you if you want to wait until first meet.
Pm'ed
shedrool83
Post Thu Mar 10, 2011 7:15 pm
That will be the suspension decision made then.
Buying Nick's cup kit :D
shedrool83
Post Thu Mar 10, 2011 9:32 pm
New washwipe bottle fitted(sent the wrong lid tho :cry: )
Numberplate surrounds on
Got the rear powerflex arb bushes on as well which completed the renewal of every bush and ball joint.
shedrool83
Post Sat Mar 19, 2011 4:34 pm
System is bled and i have heat at the heater .Think the heaters are a bit cool but i reckon once i take the car for a run it will be fine.The fan is coming on and off but the temp gauge isnt working.(see link)
http://www.e30zone.net/modules.php?name ... 89#2119489
So near :cry:
shedrool83
Post Sun Mar 20, 2011 6:11 pm
Temp gauge is sorted .
Going to get a lower degree fan switch as the fan isnt coming on until a needles width which is a bit high me thinks.
Picked this up today but i'll wait until the mot is done before i fit it
A wee crap video of it running.Dont worry the cone filter is just temp .
http://s250.photobucket.com/albums/gg24 ... V001-1.mp4
Also got a complete 13 button obc sitting so might aswell stick it in while the clocks are out.
Post Sun Mar 20, 2011 6:37 pm
Do you have a part number for the fan switch Jake? 80/88 degree switch is 61 31 8 361 787
shedrool83
Post Sun Mar 20, 2011 6:41 pm
[quote="DanThe"]Do you have a part number for the fan switch Jake? 80/88 degree switch is 61 31 8 361 787[/quote
I didnt mate cheers.
I'll get it ordered tomorrow when i'm in getting the e46 cab rear top mounts.
Post Tue Mar 22, 2011 5:29 pm
what's the deal with the e36 air box,any brackets need making etc?
i have an m30 one i was going to use.............
shedrool83
Post Tue Mar 22, 2011 8:47 pm
A bracket can be made to fit the e36 airbox (Dan has done one)
Mines is just sitting there atm but it is quite firm and i cant see it moving about much tbh.
Post Wed Mar 23, 2011 12:15 am
meant to say m30 air box ,the e36 one looks good though 8)
shedrool83
Post Sat Mar 26, 2011 5:08 pm
Seem to have a problem with the revs.
They seem slow to drop and bounce around while dropping.
Any ideas where to start looking ?I was thinking tps?
Or may it be just because the car hasnt been driven and the ecu is needing to re learn.
nickso
Post Sat Mar 26, 2011 5:30 pm
check the idle control valve is the right way round jake. sounds like the same problem i had.
shedrool83
Post Sat Mar 26, 2011 5:36 pm
Will do Nick .
There a nightmare to get at too. :x
nickso
Post Sat Mar 26, 2011 5:47 pm
yeh it took me an hour of feckin about to get it turned. had to change all the pipework too as the inlet and outlet pipes are different sizes.
shedrool83
Post Sat Mar 26, 2011 6:03 pm
What way should it be ?I'll try to see if it right or wrong before i try and turn it.
nickso
Post Sat Mar 26, 2011 6:13 pm
i can't remember. :o:
i will have to check on mine.
nickso
Post Sat Mar 26, 2011 6:21 pm
arrow points away from the inlet boot.
shedrool83
Post Sat Mar 26, 2011 6:27 pm
Cheers mate
Post Sat Mar 26, 2011 8:41 pm
Arrow indicates the air flow direction 8)
shedrool83
Post Sun Mar 27, 2011 1:33 pm
The arrow is pointing towards the the back of the inlet manifold which is correct isnt it?
nickso
Post Sun Mar 27, 2011 5:51 pm
it is. are you sure you haven't forgotten to blank something off?
shedrool83
Post Sun Mar 27, 2011 5:54 pm
Dont think so Nick.I did notice my icv is the same type as an m20 one but it worked fine in the e36
I have did away with the oil seperator so i only needed to blank one pipe if irrc.
nickso
Post Sun Mar 27, 2011 6:33 pm
i had to blank a couple of nipples on the the throtle body of the m50 manifold.
shedrool83
Post Sun Mar 27, 2011 7:50 pm
Sure i have blanked the nipple on the connector at the inlet but i'll check if i did the stub on the tb.
Kind of hope i have forgot.
shedrool83
Post Mon Mar 28, 2011 5:48 pm
I had forgot the stub on the t/b so have blanked that.
The revs now seem to drop as the should to 1k then take a couple of seconds to settle at 600.
Is this normal or is there something else up?.
Should the revs drop when you remove the oil filler cap like the m20 as removing it makes no difference.I'm guess they should and i still have an air leak. :cry:
craigieeb
Post Mon Mar 28, 2011 5:51 pm
Mebbies time to get the WD40 out?
just spray the all air pipes/air ways
and see if there is any difference in the revs,
it'll make your pipes nice and clean to
shedrool83
Post Mon Mar 28, 2011 6:20 pm
Was thinking the but also wondering if its because the ecu needs to rest its self as i havent driven it yet.
nickso
Post Mon Mar 28, 2011 7:15 pm
get it motted and take it for a thrash jake. i still think there is something else going on, took a while for me to sort out all the little niggles on mine....still doing it TBH.
Jozi
Post Tue Mar 29, 2011 12:29 am
What airbox is it your using? Any good pics of it?
shedrool83
Post Tue Mar 29, 2011 7:15 am
I'm using the standard e36 airbox Should be a pic on page 4/5
Jozi
Post Tue Mar 29, 2011 10:10 am
Just had a look there, whats the thing that sticks out from the airbox?
Your going to have to update your signature now :) What other 24v tourings are there now?
