6-point Harness Options
Motorhole
Post Sat Mar 19, 2011 4:40 pm
Just a quick one before I go drilling holes in my transmission tunnel/floorpans: could I attach my lap belts to the lower bar on the rollcage running just above the transmission tunnel?
Theo
Post Sat Mar 19, 2011 8:20 pm
I don't think the lower bar is suitable, the following photo shows my eye bolt locations which were done in accordance with the guidelines in the blue book;
Motorhole
Post Mon Mar 21, 2011 2:47 pm
Thanks for that Theo. I dug out the blue book online and looked for the ref. drawings. Will wait until I've got the seat fitted before measuring up!
djs325
Post Sun Mar 27, 2011 4:28 pm
I was going to suggest that either the FIA or the MSA would have a technical drawing which should illustrate the recommended installation angles for all 6 belts - shoulder, lap and crotch. Be sure to use the 50x75mm reinforcement plates under the floor (should have come with some in the harness kit).
I should also mention that I am a big fan of the Schroth Profi II-6H harness, which allows you to convert the lap straps to a 'pull-up' style from the traditional 'pull-down'. Really nice crotch strap design as well that doesn't dig into your bits.
E30racing.com.au - Like Production BMW Cup, but upside down!
UweM3
Post Sun Mar 27, 2011 4:40 pm
djs325 wrote:I should also mention that I am a big fan of the Schroth Profi II-6H harness, which allows you to convert the lap straps to a 'pull-up' style from the traditional 'pull-down'. Really nice crotch strap design as well that doesn't dig into your bits.
second that!
djs325
Post Wed Mar 30, 2011 10:35 am
second that!
So nice to still have feeling in your bits at the end of a race.
UweM3
Post Wed Mar 30, 2011 12:00 pm
djs325 wrote:
second that!
maybe of interest, Schroth alse manufactures the SPARCO Harness!
found thay when buying a second crotch strap for my passenger belt. the ladies still prefer the single stap design......
Mikey_Boy
Post Sat Apr 09, 2011 8:07 am
second that!
+1 :thumb:
I have these in my track car - awesome belts and can vouch for the feeling around your bits as well... winkeye
