How has everyone incorporated the water cooling of their turbos into the cooling system of the car?
I'm having enough trouble just getting the standard stuff back in as I can't remember where anything goes!
Cheers!
Won't the water be very hot after it goes through the turbo? Would it cool the TB any when it is that hot or could it actually heat it? I have no idea what temps are like for either of these or how the cooling is working, It's just something that came into my head and I thought I would post it just in case it is relevant.buster wrote:take it from the TB pipes.Instead of running it through the TB just extend the pipes over to the turbo,or if you want to keep the TB heater pipes let it go to turbo then back to TB then exit the TB in the normal way.
Aston,astondg wrote:Won't the water be very hot after it goes through the turbo? Would it cool the TB any when it is that hot or could it actually heat it? I have no idea what temps are like for either of these or how the cooling is working, It's just something that came into my head and I thought I would post it just in case it is relevant.buster wrote:take it from the TB pipes.Instead of running it through the TB just extend the pipes over to the turbo,or if you want to keep the TB heater pipes let it go to turbo then back to TB then exit the TB in the normal way.
Aston
It is supposed to heat it stop it freezing.IMO you dont need it in this country.astondg wrote:Won't the water be very hot after it goes through the turbo? Would it cool the TB any when it is that hot or could it actually heat it?buster wrote:take it from the TB pipes.Instead of running it through the TB just extend the pipes over to the turbo,or if you want to keep the TB heater pipes let it go to turbo then back to TB then exit the TB in the normal way.
Aston
