dash warning light???
burtcocain
Sat Mar 19, 2011 8:12 pm
Hi Guys,
took my 320 out for a nice drive in the sunshine today..
On the way home i noticed a red warning light on the dash next to the handbrake light!!-Im thinking that it could be the brake pad warning light???Although the brake's seem fine!!
Can anyone confirm this??????
Mnay Thanks...
Sat Mar 19, 2011 8:17 pm
it's a worn pad sensor,mine are disconnected due to greenstuff pads.
maybe a wire has snapped.you get one on the fron pass side and one on the rear drivers side if discs all round iirc
polsta
Sun Mar 20, 2011 3:19 am
or pads will feel fine but just getting low thats all,if wire not snappped/came off , mine came on last year and all was fine, but pads were worn needed changing
**BANNED**
Sun Mar 20, 2011 8:57 am
System works by embedding a wire into the sensor block,when the wire wears through it shorts to earth via the brake disc,thus putting the light on.
Therefore if the wire fouls on any other part on it's journey to the sensor,such as the wheel rim or the suspension,the light will come on.In addition to this,there is a control circuit within the instrument cluster that can play up,most likely here is a large resistor mounted on the main board behind the temp gauge.
Youth is wasted on the young.
oomz1975
Sun Mar 20, 2011 9:11 am
Do the sensors need replacing once they trigger the dash light?
charlE30
Sun Mar 20, 2011 9:57 am
oomz1975 wrote:Do the sensors need replacing once they trigger the dash light?
Yes along with the brake pads
Daimlerman wrote:System works by embedding a wire into the sensor block,when the wire wears through it shorts to earth via the brake disc,thus putting the light on.
BMW F31 335d xdrive
burtcocain
Sun Mar 20, 2011 5:55 pm
quick update.....
went to take the ns/f wheel off this morning to check for pad wear-i started to jack the car up and it slipped off the jack!!!!,damaging part of the tech 1 side skirt!!!!!!....i gonna take to the local garage tomorrow!!!!!just in :o: case i damage it even more!!!!!! :o:
Sun Mar 20, 2011 6:29 pm
all ways use a trolley jack on the lollipop bush bracket,i never use the boot jack if i can help it and then i have a wheel chock to use with it.
snakebrain
Sun Mar 20, 2011 6:38 pm
magpie wrote:all ways use a trolley jack on the lollipop bush bracket,i never use the boot jack if i can help it and then i have a wheel chock to use with it.
+1
They're for emergencies..
jamiebmw32
Sun Mar 20, 2011 8:08 pm
the same red warning light has come on my the dash. but the pad sensor is disconnected on my front pads. i have drum brakes on the back. do they have sensors on ? :?:
cee
Sun Mar 20, 2011 8:36 pm
+1
I always carry a mini trolley jack
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
**BANNED**
Mon Mar 21, 2011 2:01 pm
burtcocain wrote:quick update.....
I really do worry about yourself and your abilities to run/maintain an elderly car.
If you cannot even lift it to safely to examine problems.......
cee
Mon Mar 21, 2011 2:11 pm
+1
bpowell555
Mon Mar 21, 2011 9:42 pm
That's nothing, i released the jack under my french diesel turd with the axle stand not fully removed, put a nice dent in the sill before i realised :D
1990 325i touring
She's a minter! Best 3 years of my life - bye bye baby :D
GWB
**BANNED**
Mon Mar 21, 2011 9:56 pm
far too much chemical abuse or daydreaming going on.
EVERYTHING about motorised transport is dangerous, and should be treated as such.
Burt stick to public transport and make the roads a safer place.
Never argue with an idiot. They bring you down to their level then, beat you with experience.
Mon Mar 21, 2011 11:53 pm
daimlerman wrote:System works by embedding a wire into the sensor block,when the wire wears through it shorts to earth via the brake disc,thus putting the light on.
The pad wire does not short to earth via the brake disc or short to earth at all.
Both pad sensors are in a loop and when the loop is broken the sensor (inside the cluster) see the change in resistance and switches the bulb (on a separate circuit) on.
Tue Mar 22, 2011 12:18 am
The pad circuit is similar to a Wheatstone bridge arrangement, and will turn the warning light on if the loop is broken, changes resistance by a significant amount OR shorts to earth.
**BANNED**
Tue Mar 22, 2011 4:42 pm
It is such a shame that a certain zoner will only use his skill and expertise to critise others....
Tue Mar 22, 2011 6:58 pm
Brianmoooore wrote:The pad circuit is similar to a Wheatstone bridge arrangement, and will turn the warning light on if the loop is broken, changes resistance by a significant amount OR shorts to earth.
As im sure you know, the sensor on an E30 and any BMW for that matter works by breaking the loop and changes the resistance which is measures inside the cluster. As this is an E30 question then the correct answer is only relevant.
Besides, pad sensors that do short to earth, do not short via the brake disc!
Tue Mar 22, 2011 7:01 pm
daimlerman wrote:It is such a shame that a certain zoner will only use his skill and expertise to critise others....
Its such a shame that a certain zoner continues to post up drivel and mis inform others.....
Tue Mar 22, 2011 7:08 pm
The pad warning light on an E30 comes on initially when the wire loop in the pad sensor shorts to the disc. At this stage the light will flicker, until the wire is severed when it will remain on all the time the ignition is on.
cee
Tue Mar 22, 2011 7:11 pm
I think the final answer to this is that if the light is on there is either a lose connection somewhere or the pad is worn out. I don't think it really matters where it shorts to at the end of the day.
Not really worth arguing over. :)
Tue Mar 22, 2011 7:17 pm
How do you work that out Brian?
Tue Mar 22, 2011 7:23 pm
Because I have the full circuit, fully understand how every aspect of it works, plus it ties in perfectly with my experiences of E30 pad warning lamps over the seventeen years I've been driving them.
Tue Mar 22, 2011 7:51 pm
Well you obviously can't understand how every aspect of it works so i suggest you take a closer look at the full circuit diagram to see where you are going wrong.
Tue Mar 22, 2011 11:33 pm
I can assure you I fully understand how every aspect of the circuit works! I may not know how off of the top of my head how many Zinnobar red 325i E30s were produced during the eleventh month of 1988, or any other 'nerd' type statistics, nor do I want to, but having been a fully qualified electronics engineer for more years than you've been alive, I do understand electronic circuits, especially a relatively simple one like the circuit in question.
Jesus325iTouring
Frog freak !
Frog freak !
Tue Mar 22, 2011 11:48 pm
I also thought the same warning light comes on when brake fluid is low?
Tue Mar 22, 2011 11:50 pm
I thought it was a break in the circuit thing.. No grounding involved.. That is how it worked on my e36 anyway. Can't remember about the e30.
adit
Wed Mar 23, 2011 7:59 am
Jesus325iTouring wrote:I also thought the same warning light comes on when brake fluid is low?
stick to the subject Jesus, oh sorry, just checked the o/p and you were :teehee:
[quote="bss325i"]
Wed Mar 23, 2011 8:21 am
Thought there was a different warning light for that ?
Quick Q related to the OP - if the sensors are not present, or present but not actually clipped into the front pads will the light be on ?
Kemlo
Wed Mar 23, 2011 8:28 am
The light will be on if sensor not present - I replaced rear pads, but didn't have a replacment sensor, result - light is on.
My light also flickered for a while before staying on permanently prior to the pad replacement.
Wed Mar 23, 2011 8:31 am
Kemlo wrote:The light will be on if sensor not present - I replaced rear pads, but didn't have a replacment sensor, result - light is on.
That was what I was hoping - on my turd There is no sensor on the back at all and the sensor on the front is there but not clipped into the pads :mad: - Its on the list :D
Wed Mar 23, 2011 8:54 am
capri_rob wrote: on my turd There is no sensor on the back at all
On E30s with rear drum brakes, there is a short loop of wire connected to the plug of the fuel pump, etc. loom under the RH side of the rear seat cushion, which simulates the rear pad sensor.
**BANNED**
Wed Mar 23, 2011 12:24 pm
:ban: ?
Locked
