They are £880 ish for a set and weigh 11.2kgs a wheel..
Toplines are wank heavy wheels.
My E30 Rolling on Compomotives
the full name of the ones on the red car will be compomotive TH1780, as in, TH design, 17in diameter, 8.0 in wide. theyre the same wheel model as dans, but different size / offset.staley_turbo wrote:I think he has the comp TH, that are slightly different the the 1780's
compomotive make each wheel in a range of blank castings to suit a range of offsets, then machine them to whatever pcd / offset you want.
look at MOs, a classic 5 spoke, but the design itself varies with width and offset, a 7.5 x 17 et30 has surved skopes that go into a flat centre, an 8x17 et 10 has flat spokes and a deep recessed centre, but both are still called MOs
cheers,
harry
harry
Yep in around that, to my door they were 1200 euros and i bought yokohama 593 tyres seporate so their standing me the guts of 1700 euros under the carJhonno wrote:They are £880 ish for a set and weigh 11.2kgs a wheel..
Toplines are **** heavy wheels.
S50B30 E30
they look awsome
nice choice
lovely looking e30 you have aswell!
