M40 engine Tappet noise
joeygee
Post Thu Feb 10, 2005 8:45 pm
Hi,
I've noticed recently that my tappets (I think) are very noisy on start up and until the engine warms up. Whats stange is that they sometimes get very noisy after the engine has warmed up too.
Just after a bit of advice really; if it is them are they expensive to do DIY? Or, is it likley to be the camshaft? I have a 316i by the way.
Joe
Karan
Post Thu Feb 10, 2005 9:46 pm
its very likely that the cam is also buggered
these engiines suffer from poour oil feed to the head components hence the excessive wear
goona be pricey for parts, i rebuilt one of rthese heads and its not thatbad but not as easy as a m20 head
Karan
Post Fri Feb 11, 2005 12:01 am
I've a 318 M40 that does that. Been doing it for the whole 15000 miles I've had it. Still goes as well as it's supposed to.
It's a common characteristic of M40's that have done more than about 60k miles. My advice is to ignore it, or at most try a different oil.
welshmark
Post Sat Feb 12, 2005 8:02 am
ive got a 316i mine did it untill 150 000 miles then i had the cam shaft replaced. i only had it done because i lost power it stopped revving over 4.5k rev and up to that point it was ok but noisy. i also do 3.5k mile a month in mine and never let me down.
joeygee
Post Sat Feb 12, 2005 8:29 am
Is it easy enough to check the cams if I take the rocker cover off? I will also try a thicker oil and see if this helps. Something I've noticed recentlry is that it feels quite rough when the 'ticking' is loud, usually when its cold.
MaK-71
Post Sun Feb 13, 2005 7:37 pm
:cool: Ive got a 318i tourer m40. You can run it on the finest oils known to man and it will still rattle.
I had a full camshaft kit put on 50,000 ago its been sweet with regular oil changes,but cant belive it ~I am aware that the noise is beginning to increase again top end!!!!
You could try to replace just the oil spray bar ,(these tend to clog) cost yer about Ԛ£12 might help.
Or do what Iam going to do and drop in an M42.
:D ....... mak
Quaser
Post Sun Feb 13, 2005 10:58 pm
Let me know if you need a cam!
joeygee
Post Thu Feb 17, 2005 10:09 pm
I'll have a look on the w/e and see how it looks. Time for a oil change anyway.
