does anyone know if the m3 throtle bodies can be fitted to the m20?
how about fitting an e36 cylinder head?
throtle bodies
- Homo Hair
not without alot of work and no
nikos
what do you mean? you talk about the throtle bodies
- Homo Hair
throttle bodies might be able to be made to fit.. altho the s50 is alot longer than the m20 so it would take a v weird manifold and even then will probably not work that well
m50 is alot longer than the m20 so no way will it fit
nikos
thank you Jhonno
