Is HID really only option?
cro320
Thu Feb 17, 2011 1:28 pm
This is the situation...
I cleaned my headlights, they are mint, tried Philips Vision Plus, Osram Nightbreaker...but light output is bad...
Can I do anything except HID install?
**BANNED**
Thu Feb 17, 2011 1:45 pm
The difference between ordinary bulbs and HiD is,well,night and day.
Youth is wasted on the young.
Simon
Thu Feb 17, 2011 1:52 pm
Especially for the price of the kits these days, when they were still a new thing, kits to fit an E30 were 500gbp.
Sounds like you've tried the other options by cleaning the lights and using uprated halogens, HID's is the next step.
polsta
Thu Feb 17, 2011 2:10 pm
i have the philips x-treme bulbs, a nice improvement over standard, and still are ok, it gives a good use for the spot lamps on dark/quiet roads at night
ive contemplated hids, but concider it the dark side, people driving with hids piss me off comming up behind,and also look too bright
with hids, does that effectivly render the spot lamps useless ?
rancido64
Thu Feb 17, 2011 3:45 pm
HIDs shouldn't look too bright if the lights are properly aligned ;)
The difference really is amazing though, on my old Alfa 147 i'd used OsramNightbreakers+90% (i'll be fitting a set for my e30 full beams soon), and it was a massive improvement over standard bulbs. I was shocked at how much better again HIDs are 8)
charlE30
Thu Feb 17, 2011 8:16 pm
As already stated correctly aligned HID's don't dazzle any more than normal.. once you try them you wont go back. Get the 55w if you do get any, I've gone from the 35w to the 55w and it's like you've just gone from standard lights again 8O
@polsta, what do you mean by spotlights? E30's don't have them unless your referring to fog lights which?!?
The car's that are really bad are the brand new audi's and BMW that have the stupid retina burning lights that make it look like your lights are switched off, they take the pee pee.
BMW F31 335d xdrive
Morat
Thu Feb 17, 2011 8:33 pm
I've been using HIDS for over three years and never had anyone flash me or locals complain about them. My dips are set correctly and that's it. If you have post facelift projector lights there's no difference in beam pattern to standard halogen bulbs. BMW were early adopters of projectors so we can get away with HIDs without having to change the headlights.
agd931
Thu Feb 17, 2011 9:32 pm
Before fitting 35W HID's, (6000k)I had the Osram +90% fitted, the difference over the standard H1's was very noticeable, in my opinion the difference between the Osram's & the HID's is very minor.
The HID's are night and day compared with the standard bulbs, but I still think that the range even with the HID's is inadequate (and yes they are correctly aligned), on dark roads (most roads in Athens have inadequate street lighting) and without oncoming traffic I use the main beam in order to gain range. I also have a Ford Puma which also has projectors and it has exactly the same problem.
Does anyone have a picture comparing 35w / 55w HID's, as I am seriously thinking on fitting 55w HID's, so that I can maybe finally see the light...
1990 320i Convertible
Morat
Thu Feb 17, 2011 9:37 pm
4300k are brighter than 6000 - not by a huge amount but it is noticeable. I hope to take a comparison photo between 35W and 55W this weekend :)
I'd agree on range - but I don't have an answer apart from winding the lights up on the adjusters and that would be an MOT fail....
agd931
Thu Feb 17, 2011 9:47 pm
Glad to see that others have the range issue too... (I must be the only car in Athens with correctly adjusted lights, I think it's the British mentality in me...) I'll look forward to the pics, I've read on here that 4300K are slightly brighter than 6K, but I could not find 4300K anywhere in Athens & through the trade owing to my job, I got the 6k's noticeably cheaper than they were on Ebay in 2008.
Judging by the comments throughout this site, I think that 55w will be the only option in the end...
Fri Feb 18, 2011 12:11 am
I can't see 55W HIDs giving any greater 'range' than 35W ones. It's the sharp beam cut off that's the problem, not the level of light on the ground that's lit.
ultralinear
Fri Feb 18, 2011 9:06 pm
cro320 wrote:This is the situation...
I'm going for HIDs soon on dipped, mains and fogs (excessive! :mad: )
You don't have to worry about looking council (depending on who you ask) if you pick the correct colour temperature. You could even match the colour of your original bulbs if you wanted. So it would be barely detectable, just a hell of a lot brighter!
I'm only put off by the appearance of the ballast packs in the engine bay...
agd931
Sat Feb 19, 2011 6:21 am
my ballast packs are mounted on the back of the headlight units, which means that they are hidden by the plastic covers.
asmith88
Sat Feb 19, 2011 11:07 am
agd931 wrote:my ballast packs are mounted on the back of the headlight units, which means that they are hidden by the plastic covers.
same here you wouldnt know they where there
1990 brilliant red 318 is
jacko
Location: Too near Lakeside for comfort, even when in Spain
Sat Feb 19, 2011 11:20 am
I know there are plenty of these sets on ebay but can you guys recommend a particular brand/supplier?
And on the eighth day God created........The E30!
**BANNED**
Sat Feb 19, 2011 1:42 pm
I mounted my ballast units under the headlight units,so with the cover on,they cannot be seen.As the MoT man is currently unable to remove covers/protective coatings etc,if the lights are correctly aligned,they can be no possible reason for a fail.
Morat
Sat Feb 19, 2011 9:42 pm
The MOT tester who hates my HIDs knows they are there, but he still can't fail the car for them. Trust me, he would if he could.
Comparison shots delayed! Snow today :(
Let's see if tomorrow is better.
jonesy318
Sat Feb 19, 2011 10:02 pm
Hi guys, are the 'smiley' headlights on my 1990 2dr the projector lights,not sure how to tell as i also need toget hid's as the standard ones are poor!!!!!!!!!!
Kemix
Sat Feb 19, 2011 11:06 pm
I find my HID's a hell of a lot better than the standard bulbs and mine are only the 35w kit.
I have now mounted my ballasts behind the headlight covers 8)
Sat Feb 19, 2011 11:09 pm
Ive found prefacelift lights millions better than crappy projector smiley lights :D
Sat Feb 19, 2011 11:22 pm
Alex wrote:Ive found prefacelift lights millions better than crappy projector smiley lights :D
You need your eyes tested!
Projectors are much much better in throwing light than preface lights :D
Sat Feb 19, 2011 11:23 pm
ive had two of each now, i must of just had crap smileys then
Sat Feb 19, 2011 11:29 pm
Dirty ones you mean :mad:
Sat Feb 19, 2011 11:33 pm
Rav335uk wrote:Dirty ones you mean :mad:
even when clean they were loads worse than my sport and my old 316
I might aswell of been driving with some torches on the front of my IS, my 316i was the same. the IS had 100w bulbs and all aligned properly on a light machine thingy :D
Sat Feb 19, 2011 11:43 pm
Get some HID's then for the Sport :cool:
Sat Feb 19, 2011 11:50 pm
early lights are fooking useless !
they look cool though ! :D
Sat Feb 19, 2011 11:53 pm
Steve you Northern Fairy coont, you didn't collect on the RS's :D
Sat Feb 19, 2011 11:55 pm
Rav335uk wrote:Get some HID's then for the Sport :cool:
But that would mean fitting some smileys
and that would be wrong.
more wrong that fitting a tech II steering wheel to a tech I :D :D
Sat Feb 19, 2011 11:58 pm
bollox, I knew I forgot something, :mad:
Sun Feb 20, 2011 12:02 am
e30topless wrote:bollox, I knew I forgot something, :mad:
Lazy coooooont :D
Alex, correctomundo :cool:
Morat
Sun Feb 20, 2011 12:22 am
You could fit bullseyes, they're a bit less conspicious.
Sun Feb 20, 2011 12:30 am
Nah i like the look of the old school ones :D
Sun Feb 20, 2011 12:34 am
You mean you like driving in the dark :mad:
Sun Feb 20, 2011 12:36 am
Rav335uk wrote:You mean you like driving in the dark :mad:
less dark than me smileys :)
Morat
Sun Feb 20, 2011 6:46 pm
http://www.e30zone.net/e30zonewiki/imag ... 55whid.JPG
Not a massive difference but it is there.
