engine removal tips
Brenner5
Post Sat Jun 25, 2005 10:19 pm
i am looking to remove my engine one of these days..
are there any tips that you guys can tell me or is there a certain way to take the engine out
i have nearly disconnected the gearbox from the driveshaft (few bolts left) and removed exhaust..
320_Fizz_i
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 10:22 pm
found out recently that if poss drop the engine out the bottom tried it and was easier than lifting out imo Daz
all straaight forward and pretty easy to do
www.oldskoolfantasy.co.uk
A1BMW325iSport
Post Sat Jun 25, 2005 11:08 pm
engine and box out together
dazleeds
old skool raver
old skool raver
Post Sat Jun 25, 2005 11:10 pm
yes sorry should have said eng box together
scottybeemer
Post Sat Jun 25, 2005 11:14 pm
yeah if you have the car high enough
"you aint gonna take me alive, copper"
Post Sun Jun 26, 2005 12:59 am
4 pot engine and box comes out easy. 6 pot is a bit tighter fit, and if helps if you have one of those adjustable tilting beam things, so that you can adjust the angle of the engine and box as they come out.
Still haven't bought one myself, although everytime I remove or fit a 6 pot, I swear I'll get one before the next time.
Turbo-Brown
Boost Junkie
Post Sun Jun 26, 2005 2:13 am
Yeah, I'd definately recommend lifting the car and taking the engine out from underneath.
If you go to the "Screwfix" website and look up axle stands, you can get a set of 6 tonne jobbies for about Ԛ£20 which safely hold the car at over 600mm off the ground.
The only other thing that's handy is a large sheet of wood.
Lower the car a bit, support the engine and box with some bricks or bits of wood on the sheet. Undo the cross member bolts. Then, lift the car nice and high and pull the whole lot out from underneath :)
P.s. Process has been simplified for my drunken mind. :lol:
Brenner5
Post Fri Oct 14, 2005 11:25 pm
i will probably get the hydraulic hoist to remove the engine from the top..
what should i replace when putting the other engine in??
so far i have got:
downpipe gasket
engine mounts (if they are worn)
I have yet to check the cables that connect at the bottom of the engine.. not sure how difficult they will be to reconnect.
any other advice is more than welcome :)
320_Fizz_i
Andy_magic
Post Sat Oct 15, 2005 12:43 am
When I pulled the motor out of my car I split the engine and box, took a while to get the bell housing bolts out, but I had 2 long extension bars and a Uj on the ratchet which helped alot.
Hydrualic hoist hooked straight on the inlet manifold to rocker cover lifting point worked really well.
alan325i
Post Sat Oct 15, 2005 8:47 am
When i did my 6 pot, tok it out the top with the gear box attached. Just need to jack up car enough so it clears the gear box.
Took me 2 days to get it out and new one in, but then it was my first time and weather was pretty bad.
Brenner5
Post Sat Oct 15, 2005 3:03 pm
how about rewiring the cables that go under the engine or are they staright forward??
320_Fizz_i
