S62 Flywheel on an M60B40
As above really. Will it fit? Does anyone have any idea how heavy it is? Can I get a clutch to allow me to use it with the 5 speed 'box?
BMW e21 track car supercharged s14 cage and fabrication by www.chizfab.com
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Spotted a used one locally for £150. I only need a flywheel, got a clutch although may need to upgrade as its from an m60b40.
Are those guys in the UK?
Yeah they are in the UK and clutch is s62 specific, have you priced one up yet
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Not yet, I'll need to start having a look though, I have everything else I need to get the engine in now.
I have read on another forum that the E36 M3 clutch can be used, or at least the pressure plate can. Need to do more research!
http://www.r3vlimited.com/board/showthread.php?t=189921
Could I borrow the engine mounts for a day to see how the m60 sits in the e36
Jason
Jason
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
Yeah no problem, I wont be using them for a while yet anyway.
Want a hand lifting it in?
The 300mm.de mounts won't help in fitting M60 to E36...
To the topic, the flywheel bolts straight on and you should be able to use M60B30 / M62B35 clutch packet with it. Not 100% sure, though.
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
I know but with the sump off and the oil pump off it will give us a far better idea what needs to move and get some measurementsThe 300mm.de mounts won't help in fitting M60 to E36...
Z3M Coupe for sale
69 Alfa spyder
Z3M Coupe for sale
69 Alfa spyder
