OK heres the deal............
M20B25
Cold Engine = Fan spun by hand easily, very little resistance = NORMAL
Hot Engine = Fan spun by hand easily, very little resistance = FAULTY
Is this correct ?
There is no (detectable) difference is the viscous fan clutch resistance between a hot or cold cooling system.
Viscous Fan Clutch, need fault confirming
kam-325i
touringshed
if u can stop the fan easly while engine at temp then it needs replacin
Pal318is
A little unsure about the 2.5i's, but if it's the same as 318is, then is it not the Viscous Fan Coupling that needs replacing?? I had the same problem and replaced the coupling and bingo!! Good as new!!
Pal
[img]http://
[img]http://
SwirlyE30
Dont mean to hijack your thread, but my viscous sounds like a jumbo jet.It seems to be over working, could it possibly be locked somehow?
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
Pal318is
It's probably not on there correctly, if it's new....If it's not, then it might have been put on to tight, which would be difficult to do as it's reverse thread..try taking it off and putting it back on again, checking out the coupling when you take it off.
HTH
HTH
Pal
[img]http://
[img]http://
Simon
Sounds right, if the fan is easy to move when the engine is very hot, then it's faulty, all E30's shared the same viscous coupling.
If your viscous is wooshing constantly at any temp even low temps, then again this is faulty and needs replacing.
johnna
- E30Zone Irregular
The test is, with the engine running hot, stick your fingers into the blades of the fan.
This will show that there is definitely something wrong with your brain.
johnna
- E30Zone Irregular
SwirlyE30- could be the water pump on the way out. Check for a leak from the little aperture on the pump. Any leaks, swap the pump. The pumps are pennies really, best swap it.
E30Mark
How easy is it to swap the pump with no fingers left?
PM for details
PM for details
I think you're propbably looking for a fault that doesn't exist.kam-325i wrote:OK heres the deal............
M20B25
Is this correct ?
The fan should spin easily by hand with the engine hot or cold. It should only lock up on an engine which is beginning to overheat.
Run the engine with the car parked and watch the temp gauge. If it does not go up past normal, then your viscous coupling is probably working OK.
You should be able to hear when the fan cuts in by the extra noise.
kam-325i
I am having a overheating problem, sat in traffic, temp rise's considrably, start normal driving again, temp come back down to normal.Brianmoooore wrote:I think you're propbably looking for a fault that doesn't exist.kam-325i wrote:OK heres the deal............
M20B25
Is this correct ?
browny
don't forget to do as mentioned before and check the water pump. I had a problem like yours and found out just in time that it was the water pump. You do not want to have that die on you and your engine overheat cause of no cooling.
In that case, the viscous coupling is almost certainly duff.kam-325i wrote:I am having a overheating problem, sat in traffic, temp rise's considrably, start normal driving again, temp come back down to normal.Brianmoooore wrote:I think you're propbably looking for a fault that doesn't exist.kam-325i wrote:OK heres the deal............
M20B25
Is this correct ?
