Inlet mainfold?
chu346
Post Fri Feb 11, 2005 6:02 pm
Does anyone know if the inlet manifolds on the 325 engines are all the same or if there are some that are different?
E30Adam
Post Fri Feb 11, 2005 6:03 pm
All the same mate!
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
chu346
Post Fri Feb 11, 2005 6:13 pm
well the guy who's fitting the engine is saying there different, and thats why i've been waiting since tuesday for the car.
Ill have him tomorrow! :chainsaw:
E30Adam
Post Fri Feb 11, 2005 6:27 pm
There's no difference accross the 325i range.
325e's had a different one as did 320's and 323's but all 325i's have the same manifold. I have about 6 here if you need one!
popupstands
Post Fri Feb 11, 2005 6:39 pm
would there be any benefit from changing 325i manifold to 325e and will it fit ok without problems
E30Adam
Post Fri Feb 11, 2005 7:00 pm
popupstands wrote:would there be any benefit from changing 325i manifold to 325e and will it fit ok without problems
Why would you want to do that?
E30Adam
popupstands
Post Sat Feb 12, 2005 8:14 pm
someone was advertising on ebay that their was power gains fitting a 325e Manifold, I don't know if true or not
E30Adam
Post Sat Feb 12, 2005 9:40 pm
popupstands wrote:someone was advertising on ebay that their was power gains fitting a 325e Manifold, I don't know if true or not
Most definately not, the 325e inlet is much more restrictive than the 325i one. It would work the other way round though if you happened to own a 325e and wanted to fit an "i" manifold
Andy335Touring
Post Sat Feb 12, 2005 10:08 pm
E30Adam wrote: It would work the other way round though if you happened to own a 325e and wanted to fit an "i" manifold
Not unless you ported the head to match
E30Adam
Post Sat Feb 12, 2005 10:26 pm
Yes you would need to do that to do a proper job.
It would still give small gains over the eta manifold though.
