Steering rack conversion info needed (e46 330 ci sport rack)
tomislav
Post Fri Feb 11, 2011 11:43 pm
Hey people.
I know that the z3 rack conversion is popular but i've also heard talk on here that an e46 330 ci sport rack can be fitted with about 2.5 lock to lock.
Can someone point me in the direction of a guide on how to do it?
Or gimme more info generally?
charlE30
Post Sat Feb 12, 2011 11:56 am
The standard E30 steering linkage bolts straight up on the E46 330ci rack, I removed the rubber gilbo on mine to give a bit more clearance around my M30 manifold. I used reshaped E30 PAS pipes on mine as it came without any pipework. You could easily get proper pipes made up but will cost. The 330ci rack should have an oil cooler loop (as fitted on the E46) in the pipework, mine hasn't and works perfectly.
You can't use the E46 track rod ends as they don't fit the E30, you can bolt E36 ones upto the E46 tie rods which work perfectly or you can fit E30 tie rods and track ends to the rack.
Use the forward mounting holes with the same spacers as used on the E36 rack swap, as far as I'm away there are no guides as it's so simple.
Do a search on both E36 and E46 rack swaps, there are shed loads of threads already on here. The better ones are from a while back.
The E46 swap is easy :D
HTH
Charlie
BMW F31 335d xdrive
tomislav
Post Sat Feb 12, 2011 3:34 pm
The zone comes good again!
Thanks fella
charlE30
Post Sat Feb 12, 2011 6:19 pm
tomislav wrote:The zone comes good again!
Thanks fella
No worries mate, you'll love the feel of it when it's fitted :cool:
I'd been driving with it for about 6 months and had to borrow my other halfs tourer, nearly crashed on a corner as I got use to the speedy turn of the E46 rack and had forgotten how disconnected the standard E30 rack is. (not literally but you'll see what I mean)
Have fun :thumb:
Charlie
BMW F31 335d xdrive
tomislav
Post Sat Feb 12, 2011 7:41 pm
Well i take mine to the nurburgring at least once a year and do both track days and drifting with it so it should be a proper sharp tool soon!
What are they lock to lock, 2.8, 2.5?
ian332isport
Post Sat Feb 12, 2011 8:36 pm
tomislav wrote:What are they lock to lock, 2.8, 2.5?
Not as quick as that. It's around 3 turns, but the feel is superb.
Ian.
e301988325i
Post Sun Feb 13, 2011 10:08 am
If you search for my username crossreferenced with E46 rack or similar, the part numbers for the exact rack should come up. My one was fitted with a combination of only E46 and E30 parts. The stock E30 linkage bolts straight onto the spline of the E46 rack. but needs shortening, I removed the ruber guilbo and bolted the two halves together. You need to hack saw off the small central spigot but other than that it is easy. Use nyloc nuts and anti rattle/spring washers!
You should fit a cooler, it's dangerous when/if the fluid overheats.
I said:
e30topless said:
lock the wife in there
MrBenn
Post Sun Feb 13, 2011 10:47 am
e301988325i wrote: You should fit a cooler, it's dangerous when/if the fluid overheats.
I remember you saying about the cooler before, did you just use the coil that came with the rack? Does this fit behind the sump? When I first fitted a e36 rack, I forgot to take the bolt out from where the cooler goes, after half a track day round combe it had put a hole in the sump!
Bristol_Jer
Post Sun Feb 13, 2011 11:21 am
Does the rack have to from a 330i sport, or will a normal e46 330i rack fit? There were a few normal 330i racks on ebay when I looked the other day
tomislav
Post Sun Feb 13, 2011 11:26 am
I think the 300 ci sport rack is a quicker ratio
As for the oil cooler, i've already heard rumours that under hard use the fluid boils then your steering goes to shit! They came with coolers for a reason, i'll retro fit mine up infrnt of the rad probably
MrBenn
Post Sun Feb 13, 2011 11:30 am
Its the e46 sport rack, not specific to the 330ci, I have the part number somewhere, or like e301988325i said, do a search he has given the part number a few times in the past.
e301988325i
No, it had to be removed for clearance, mine's behind the kidney grill in front of the rad, from an E46 320d, but they are all the same.
Cheers Alex
I said:
e301988325i
Post Sun Feb 13, 2011 11:33 am
If you do not get the exact correct rack, you will be able to dry steer with just youur little finger, it will be ridiculously light.
There have been discussions as to whether it is fitted to al sport option E46's or just E46 clubsports. My opinion is the latter, but someone is welcome to prove me wrong.
I said:
ian332isport
Post Sun Feb 13, 2011 11:36 am
Bristol_Jer wrote:Does the rack have to from a 330i sport, or will a normal e46 330i rack fit?
You need the 330ci Clubsport rack. If it's not from a clubsport, it will have a ratio the same as a standard E36 rack - approx 3.4 turns lock to lock.
MrBenn
Post Sun Feb 13, 2011 11:38 am
Have to disagree Ian, mine came from a 320d, it is 3.0 turns lock to lock and has the
6 755 067 part number
MrBenn
Post Sun Feb 13, 2011 11:40 am
Cheers Alex
Cheers, thats what I thought.
tomislav
Post Mon Feb 14, 2011 7:53 pm
e301988325i i've searched for the first post you put up on this but can't find it.
Is the part number 6 755 067 in MRBenn right?
e301988325i
Post Mon Feb 14, 2011 9:55 pm
e301988325i wrote:I've just been outside and jacked my car up, I've listed my purple label below, middle line is last 7 digits of part number I believe. It looks like you've not got a sport one. I don't know if it might be possible to reduce the pressure to the rack somehow??
7852 974 679
6 755 067
006888 0701
http://www.e30zone.net/modules.php?name ... t=e46+rack
I said:
TouringMatt
Post Mon Feb 14, 2011 10:32 pm
Like this?
Last stamped code is different, does that make difference do you think?
tomislav
Post Mon Feb 14, 2011 11:53 pm
Sweet! Cheers for that, i'll check it with bmw over the road in the morning
e301988325i
Post Tue Feb 15, 2011 7:50 pm
I'm fairly sure 7852 974 679 6 755 067 is the part number and the stamped numbers on the left are batch identification, on the right date id mine's 0701 (July 2001) yours 0801 (Aug 2001).
I said:
TouringMatt
Post Tue Feb 15, 2011 7:59 pm
I hope its right, i picked one up today :D
Ended up with one dated 0202 so its even later? didnt come with any pipework apart from the rigid fitted lines, but has both banjo bolts
Bristol_Jer
Post Tue Feb 15, 2011 8:14 pm
I've got a 330ci rack being delivered, not sure if it was a sport or not but took the gamble! I'll post up pics and amount of turns lock to lock when I get it
charlE30
Post Tue Feb 15, 2011 8:31 pm
Nice one Matt :cool: you going to "reshape" your original pipes or go posh and get some made?
Bristol - fingers crossed mate it is the right one, if not it'll still be a massive improvement over the old E30 steering.
BMW F31 335d xdrive
Bristol_Jer
Post Tue Feb 15, 2011 8:39 pm
I've got an e36 rack as well, going to try both and see which I prefer :)
tomislav
Post Tue Feb 15, 2011 9:50 pm
This looks like it could be a pretty awesome mod then yeah?
I think the old girl deserves a spruce up after the abuse i've given her lol.
TouringMatt
Post Tue Feb 15, 2011 10:40 pm
Whats up with realOEM rack listings? It does not seem to reconise loads of E46 rack part numbers. Just had a scan of ebay and none of the codes i found brought anything up??
It does not even show anything for 6 755 067, even tho i have one sitting in my boot, so i know it exists! I just hope i have the right one :cry:
charlE30 wrote:Nice one Matt :cool: you going to "reshape" your original pipes or go posh and get some made?
Will probably buy some or if i cant wait, get some made up. Probably wont happen until the summer tho! :roll:
TouringMatt
Post Tue Feb 15, 2011 10:59 pm
Doing some research - always wise after you've spent your money :(
Rack Info
http://www.bimmerforums.co.uk/forum/f74 ... es-t32779/
Making the steering heavier?
http://www.bimmerforums.co.uk/forum/f2/ ... ou-t55956/
And more
http://www.bimmerforums.co.uk/forum/f74 ... il-t32714/
It seems BMW made the steering originally heavy, over-compensated and made it too light, and hit a middle ground. Could be a bit of a lottery!!!
Matt
e301988325i
Post Wed Feb 16, 2011 11:06 am
Good research touringmatt, they never had these problems with the E30 racks!
I said:
tomislav
Post Wed Feb 16, 2011 11:15 pm
Ok, popped into BMW just over the road from where i work.
The part number that e301988325i has (end 67) has now been superceeded to the other number (ends 68).
There was no special listing for a 330 ci clubsport rack.
Also, trade price to me for an exchange rack... £1260 inc vat!!!!!!!!!!
F****************CK!!!!!
Post Thu Feb 17, 2011 8:15 am
:eek:
e301988325i
Post Thu Feb 17, 2011 8:26 pm
that's got to go in the parts prices shocker thread!
I said:
tomislav
Post Thu Feb 17, 2011 8:31 pm
Where's the thread? i'll put it there.
Price breakdown:
Rack - £900odd + vat
Surcharge - £175 + vat
= Total was £1260!
tomislav
Post Thu Feb 17, 2011 9:12 pm
Been scanning ebay, found a rack with the same 6755067 part number.
Is this the rack i need yeah?
If so i'm buying tonight.
e301988325i, what dya think? its the same 7 didits as the pic you posted
e301988325i
Post Fri Feb 18, 2011 6:07 pm
Monkey (Matt), CharlE30 and I have had success with that part number.
I said:
