Why not to fit the square mounts,,,
Post Wed Feb 09, 2011 8:40 am
Duke137
Post Wed Feb 09, 2011 8:52 am
What you been doing!!!!!!!!!!! :eek:
craigieeb
Post Wed Feb 09, 2011 12:12 pm
The dirty little slaaaaaag
how long they been in for?
Post Wed Feb 09, 2011 12:43 pm
Used them for a couple of years on my M50B25, they were fine when fitted to the chromie with the 2.8 but I noticed the drivers side started to crack/craze which I assumed was from the heat being close to the exhaust, so the manifolds were wrapped. The drivers side seemed to deteriorate quickly with the 2.8 (240hp) so when I fitted the alpina after 3,000 miles of running the 2.8 I didnt use it again but the passenger side was still good, ive done about 1,000 miles with it and its now in two pieces :?
AKG mounts will be going on now...
shaun_89
Post Wed Feb 09, 2011 1:01 pm
Which akg mounts are the best? Would the solid metal ones be far too harsh?
craigieeb
Post Wed Feb 09, 2011 1:02 pm
Are you going for the polly ones or the Alloy ones?
Wouldnt mind going down the alloy mount route my self,
engine/gearbox/diff
but then the only weak link would be the centre bearing on the prop
Duke137
Post Wed Feb 09, 2011 1:09 pm
DanThe wrote:Used them for a couple of years on my M50B25, they were fine when fitted to the chromie with the 2.8 but I noticed the drivers side started to crack/craze which I assumed was from the heat being close to the exhaust, so the manifolds were wrapped. The drivers side seemed to deteriorate quickly with the 2.8 (240hp) so when I fitted the alpina after 3,000 miles of running the 2.8 I didnt use it again but the passenger side was still good, ive done about 1,000 miles with it and its now in two pieces :?
A must see for anyone doing the M5x swaps then
e30-EVN
Post Wed Feb 09, 2011 3:57 pm
Agreed ^
Its not about having that happen :cry:
ross_jsy
Post Wed Feb 09, 2011 11:48 pm
AKG do specific ones for m5x and s5x swaps with a special angle and IIRC group N grade poly. I have a set.
Expensive mind. Think I paid around $200 but well worth it.
nickso
Post Thu Feb 10, 2011 12:48 am
i have them too. been fitted a year and not moved a millimetre in the relatively small 2k that i have done.
'88 e30 328i M52 track bint.
ross_jsy
Post Sat Feb 12, 2011 8:55 am
For anyone who is interested:
http://www.akgmotorsport.com/catalog/ca ... M50%20Swap
Second from the bottom.
