A recent problem my IS has developed is when you say stop at a set of lights the revs drop as would normally happen but then stick a about a 1000 for about 5/6 seconds before dropping to a normal idle. Its as though its running on cold start.
Its not a sticky throttle cable as I can't get it happen when the car is stationary.
I admit that the temp gauge never gets out of the blue but as far as I'm aware that side of things is indepentdant of the running.
Any ideas would be of great help because not only is it anoying but fuel economy is down which is not good seeing a tenner don't get you far these days.
