M52 b30 stroker rebuild back on the road
Awsome
MurphyE30
Just had e read through, great stuff Mick
look forward to when its done
will be nice to get some meets sorted
Nice collection of parts, LSD FTW
Is it running yet?
Is it running yet?
aj_mckay
Those long drop links look like E36 M3 items to me that mount onto the shocks.magpie wrote:
not sure what the long drop links are fornot an e30 i'm sure
i will get one sorted for end of FebMurphyE30 wrote:Just had e read through, great stuff Micklook forward to when its done
MurphyE30
will we all be road worthy by then LOLAlex wrote:i will get one sorted for end of FebMurphyE30 wrote:Just had e read through, great stuff Micklook forward to when its done
Haha Lets hope soMurphyE30 wrote:will we all be road worthy by then LOLAlex wrote:i will get one sorted for end of FebMurphyE30 wrote:Just had e read through, great stuff Micklook forward to when its done
craigieeb
MurphyE30
Get the spanners out Mick
He has no excuse its been a lovely day here today
Dezzy
- CR24v it's a lifestyle
Make it march and I will bring the Chromie. I am not taxing it till the start of the month.
we should have a "get Micks 24v Finised" meet like we did with yours Dez, before the slight glitch
Dezzy
I would be up for that as soon as mine is finished.
Dezzy
Sunday mate.
awsome
i had a good day fraggin the tech11 turd
bravo craig, shouldn't take you long getting here to help me in that
appreciate the offer of help lads and i'll be cracking on with the build when that silver scrap 2dr is weighed in on friday
+ a yard full of scrap turds
time to crack on now the frag turd is Dead
more council activity !
£70 for this collected and of to make rusty toasters:D
steering rack time.
bought these yesterday from gsf
fitted today - jobbed!
having a look at my modded linkage it has coarse splines on one uj for the steering column and fine splines on the other for the e36 rack so this one works
i have acquired a couple of e34 uj's in case i have any clearance issues with the zaust fanimould.However,only one will fit to the e36 rack and the other has fine splines also so won't fit the coarse splines on the column
what's the score here then,i thought x2 e34 uj's were needed with a splined middle jointer so how is it supposed to work that way when only one end fits ???
where does the rack go now then,in the front cross member holes or the rear ones and do i put the spacers either side so it's in the middle or at the top so it's lower or at the bottom so it sits higher ? any thing needed to be trimmed/adjusted etc before i go ahead and fit it ????
i'd like to get it right 1st time if poss
Dezzy
In the rear holes Mick.
craigieeb
Ooooer missusDezzy wrote:In the rear hole Mick.
M50 Turbo!!!
I shall say no more
Dezzy
If you have choice always pot the brown. It's in the rules
rancido64
Awesome comment is awesomeDezzy wrote:In the rear holes Mick.
MrBenn
E36 rack goes in front holesDezzy wrote:In the rear holes Mick.
cheers for that link,it will come in handy soonMrBenn wrote:E36 rack goes in front holesDezzy wrote:In the rear holes Mick.
Dezzy
^ not true my friend. Mick has a Danthe steering bar. This means you keep original rack possision. This keep everything correct. Rear holes ftw Mick.
MrBenn
Dezzy is correct. I have just gone and tried it on bits I have laying around. God knows why I didn't put it in there when I fitted it, probably just read they were the holes to use. I don't know how Lee was having a problem in that link I posted (although I was just playing with a lhd e36 m3 rack, could be different slightly)
brown ftw
You need to rebuild the one UJ with part of an E30 linkage Mick, so it fits the column spline.
I can do this for beer £
Dezzy
Mick send it to Dan. I did.
I fact the more you can get him to do for you the better IMO.
Getting there mick.
You cant beat shiney new parts
if i have any issues with the modded linkage i have Dan i'll post one e34 uj to you with the top half from an e30 one and i'll need the connecting splined bar to go with it to finish the job,i may need some of those lurrrvley pas pipes also when the time comes to bolt it all together which will be very soonDanThe wrote:You need to rebuild the one UJ with part of an E30 linkage Mick, so it fits the column spline.
If that welded link was made for an E30 rack you will have to fit the E36 rack in the front holes
cheers, i'll be fitting the rack and front legs tomorrow.DanThe wrote:If that welded link was made for an E30 rack you will have to fit the E36 rack in the front holes
