does anyone know if 2.0 and 2.5 m52 manifolds the same size as the 2.8?
i ask as i picked up a set off the floor of my scrappy but i have no idea what size engine they came off, it was an e39 though.
exhaust manifold sizes.
nickso
- Location: Go do that voodoo that you do so welllllllll!!
'88 e30 328i M52 track bint.
Duke137
I think the M50 is a cast manifold and the M52's are tubular AFAIK
e30-EVN
Ferg is correct, the m52 are tubular and these are needed for m50 conversion as they can be cut down to fit around everything.
The cast mani's won't go in and cannot be molested like the tubulars!
I would say that when coupled to a decent exhaust the tubulars would flow much better aswel
nickso
thanks for the replies but thats not what i'm asking chaps.
the tubular manifolds on the m52b20 and m52b25, are they the same physical size as the tubular manifolds on an m52b28?
They are the same part
nickso
cheers dan.
