I use the key and can't get them off (they just spin). P.S. Im a monkey
How Do I Use Standard Locking Wheel Nuts
doug325i
orangecurry
errr from memory don't you hold the outside, put the key in and turn it through 90 degrees, then the whole top bit comes off?
Jesus325iTouring
- Frog freak !
The best way to use standard locking nuts is to get a powerful drill and drill the bloody things off and replace them with decent ones,when your broke down on the side of the M5,in the rain,with a blown out tyre,you'll understand why I suggested this if you don't change them for decent ones!
E30Mark
Put the key in and turn it through 90 degrees, and pull damn hard, you may need to wiggle it a bit to get them off. The key latches onto the top of the locking nut hence you can pull the nut off with the key.
When you do eventually manage to get the useless thing off chuck the locking part away, as Jesus said, they are bloody useless!. But i guess if we can't get them off with the key then the thieving scum bags will not get them off in a hurry either !
PM for details
PM for details
A1BMW325iSport
the best bmw ones are the splined bit ones i have them they are great
yup and Ԛ£20 too, as said those standard one are shite, hammer and chisel is good for giving them a hard time too, smash the lock to pieces!A1BMW325iSport wrote:the best bmw ones are the splined bit ones i have them they are great
doug325i
Thanks everyone - just needed a bit of force - they are rubbish think I will take them all off, whos going to want to steel standard bmw wheels anyway?? maybe back in 1989 I supose
Doug
Doug
