Ideas on how to secure the bottom off the e28 rad?
sheebie
Post Thu Feb 03, 2011 3:13 pm
as above I have fitted this today, the top is very straight forward to secure, but how is everyone securing the bottom?
leeparkes
Post Thu Feb 03, 2011 5:10 pm
Cable tie's FTW :D
Post Thu Feb 03, 2011 10:58 pm
leeparkes wrote:Cable tie's FTW :D
Seriously 8O
leeparkes
Post Thu Feb 03, 2011 11:35 pm
Yes, once its secured at the top with the bolts use a cable tie through the fins just to stop it from moving at the bottom, it doesnt need to be tight its just to hold it in place.
You will know when yours is fitted :)
Post Thu Feb 03, 2011 11:43 pm
Cool, as long as they out of sight :D
sheebie
Post Thu Feb 03, 2011 11:45 pm
I thought you were joking too, I think you know what your talking about lol
Thanks once again Lee :thumb:
leeparkes
Post Thu Feb 03, 2011 11:50 pm
You only need one at the very bottom of the rad and just tighten it till you start to see the rad moving back
Use a decent quality one though as rads do tend to get hot :)
Post Thu Feb 03, 2011 11:51 pm
Your supposed the weld a bracket onto the botoom, but cableties is "Diffin" :mad:
Post Fri Feb 04, 2011 12:04 am
You got a bracket on yours Rav?
leeparkes
Post Fri Feb 04, 2011 12:08 am
With just one E30 rad bracket removed (part of the shell) the E28 rad almost wedges in place between the chassis rail and the other bracket, all it needs is a tie as some extra security.
I think if both brackets were removed the rad would flap about at the bottom.
Ive seen cable ties hold a lot worse, was it cypriotgeeza whos gearbox was held on with them :mad:
Post Fri Feb 04, 2011 12:16 am
N Imy, i'm running with the E34 rad with no problems, so it's staying.
Lee, now that's "Diffin" :mad:
TouringTash
Post Fri Feb 04, 2011 12:17 am
You can get cable ties with a metal strip built in these are stipulated on any commercial or industrial cable installation when the cables are being suspended or run on trays due to the cables dropping if a fire breaks out.
Though in practice most companies balk at the price and I've yet to meet a QS that checks this.
Just get a couple of brackets made and bask in the oem homo glow it will create.
Ok its not an OE part but any job thats done once then forgotten about does achieve a certain smugness.
Not knocking Lee though as from what I've seen him achieve (on his own, in the open) cannot be knocked or disparaged.
318i Touring
Post Fri Feb 04, 2011 12:19 am
Diffin' FTW :D
zaust
Zone day release
Post Fri Feb 04, 2011 12:42 pm
I'm using two bigass cable tie's and had zero problems.
M30 Tech 1 Touring on gas.
sheebie
Post Sat Feb 05, 2011 12:27 am
Cable ties it is then for the time being.
gareth
Post Sat Feb 05, 2011 11:42 am
I've had cable ties on mine as a temporary measure for, err, 4 years i think!
I did upgrade to some of the re-usable types once though :)
Bristol_Jer
Post Sat Feb 05, 2011 5:54 pm
What does 'diffin' mean??
Post Sat Feb 05, 2011 9:00 pm
Drifting :P
Cypriotgeeza
Post Sun Feb 13, 2011 2:00 pm
leeparkes wrote:Ive seen cable ties hold a lot worse, was it cypriotgeeza whos gearbox was held on with them :mad:
Mate the whole car was held together with them..whoever done the conversion must have had a fetish :mad: lol
from my memory the things which where cabletied where:
-Exhaust to the brackets
-Gearbox linkages, and gearbox itself in some parts where they couldnt get bolts too :mad:
-The expansion bottle
-wiring (which is reasonable i guess)
-radiator Which you can see in this pic:
and thats just from my memory!
Check my M30 build threads:
rancido64
Post Sun Feb 13, 2011 3:17 pm
ImysE30 wrote:Drifting :P
Not at all, they're two different things ;)
leeparkes
Post Sun Feb 13, 2011 3:22 pm
Enlighten us :D
