Mikey_Boy wrote:I think the ratios for the 6 speed are as follows??
1st Gear Ratio 4.23:1
2nd Gear Ratio 2.51:1
3rd Gear Ratio 1.67:1
4th Gear Ratio 1.23:1
5th Gear Ratio 1.00:1
6th Gear Ratio 0.83:1
But I could be wrong! I believe that there are (potential) synchro issues due to the clutch not engaging or disengaging properly - apparently sorted with a braided clutch slave hose?
Personally I think this would be quite a weapon - the only issue is the big gap between 1st and 2nd gear - depending on the use, I am sure a diff could be used thats good for both road or track?
DanThe is the expert here - I am just an interested observer!
Those are S50 Getrag 6 spd ratios, the 320d ZF ratios are only slightly different,
1st = 4.35
2nd = 2.5
3rd = 1.67
4th = 1.23
5th = 1
6th = 0.85
I am using a 3.15 ratio diff and find it very good
This is the least of your worries though, the box is tilted 10 degrees extra compared to an M50/S50 box, check out turks thread for some pics, the linkage is an arse...
The input shaft is shorter, the spline is the 'new type' so you only have solid clutch plates on the shelf, the slave mounts further back in the box.
I bought mine without realising any of this, I jumped in as it came up with only a few thousand miles and it was very cheap, if I was to do it again id go for an M54 6 speed.
I still need to make the clutch better, the release is not quite fast enough so the pedal is long = slow changes. I want to get this sorted for spring time when it comes out of hibernation
