clay baring
pigman
any body done it?
Dan320is
Yes, many times. What do you need to know?
pigman
does it make much difference ? will it work well on a white car? how clean does the car need to be before claying?
Clay bar is a must on a white car if you want it nice and shiney
Dan320is
Clean the car as you would normally then wipe the panels with some tar & glue remover. Claying is easy and you can't really get it wrong.pigman wrote:does it make much difference ? will it work well on a white car? how clean does the car need to be before claying?
After claying, polish the car with a product that has some 'cut'. Autoglym Super Resin will do if you're starting out. Then a wax on top to protect the work you've just done.
Clay barring will make washing, polishing and waxing alot easier in future.
appletree
How often do you need to do it? I bought the meguires clay kit abit back and it easy realy impressive stuff, but do you do it ever time before you wax or polish?
Dan320is
No, not everytime. I clay my car after every third wax to stop uneven wax build up but I am a bufty.appletree wrote:How often do you need to do it? I bought the meguires clay kit abit back and it easy realy impressive stuff, but do you do it ever time before you wax or polish?
