Scorpion Exhaust back box mount?
josh-hocking
Teenager with Taste !
Fri Jan 28, 2011 8:12 pm
Hi guys.
I have got a backbox for my car (318) and i have come to fit it.
I cut part of the pipe off the old backbox and welded it to the new, so i have the same length and shape - i did this as i then thought it would be a straight swap haha..
so i held it to the car and fitted it to the centre section and everythings perfect except the straps to mount the actuall box, i have made them smaller but it wont hold it in the correct position - just wondering if there is a scorpion mount specific? i have googled it and found nothing up to now.
Josh
Fri Jan 28, 2011 8:24 pm
that's my old le mans back box from touring whores m42'd touring 8)
he never mounted it properly either.
if you have a welder you can make something that will work if yo can't get the right part .
josh-hocking
Fri Jan 28, 2011 8:28 pm
Yeah i got a welder... no idea what to make or where to mount it to though... any ideas?
Fri Jan 28, 2011 8:35 pm
use another strap and weld it to the one that is round the box ?
or summit like that but it needs the part the for the rubber hanger to wrap round so you get no vibration. i take it you trimmed the valance and never butchered it like some i've seen. 8O
josh-hocking
Fri Jan 28, 2011 8:39 pm
Hmm il get thinking....
And regarding the valance, i didnt want to cut it so i bent it out of the way, it will bend back it need be aswell......
josh
**BANNED**
Fri Jan 28, 2011 9:02 pm
Is it possible to adapt a standard wrap-round strap thingy?
That way you will get the difficult bit that hangs from the rubber readymade..
Youth is wasted on the young.
Fri Jan 28, 2011 9:09 pm
have a look at the pic Dan put up on my thread here Josh. Maybe an idea?
I had the same problem mounting my M3 scorpion system to a 4 pot ready turd.
http://www.e30zone.net/modules.php?name ... start=1775
josh-hocking
Fri Jan 28, 2011 9:29 pm
hmm that might work actually lee as the problem is along the line of that.....
and dailmerman.... yeah that too would save alot of messing!
thanks
