Sub sizes
Post Tue Jan 25, 2011 6:51 pm
I heard the height from the boot floor to the hood compartment on a cab is 280mm.
This means most 10" subs just about wont fit.
Is an 8" sub sufficient for a cab?
Post Tue Jan 25, 2011 7:18 pm
Sorry can this be moved to Styling and ICE.
Sanchez
Post Tue Jan 25, 2011 7:24 pm
You can build a box so that the sub faces up if you want.
Post Wed Jan 26, 2011 4:29 pm
A 10" sub will fit but will be tight, personally 8" is too small :)
_Jay_
Post Thu Jan 27, 2011 2:00 pm
Im fitting a 12" in mine, the majority of it will be under the hood compartment, and then it will stick out a little and have a step up to accomodate the full size of the sub.
chu346
Post Thu Jan 27, 2011 2:06 pm
I measured 11 inches in my old cab. I'm sure you could fit two or three 10's in there, IF you build the box right.
Post Thu Jan 27, 2011 2:10 pm
I'm inclined to go with a design similar to below now, at least that way you won't have as much issues with sub size :)
Post Thu Jan 27, 2011 6:01 pm
I just want to buy a off the shelf sub and box.
chu346
Post Thu Jan 27, 2011 8:50 pm
Blitz wrote:I just want to buy a off the shelf sub and box.
:gay:
Post Fri Jan 28, 2011 1:35 pm
:gay:
Exactly :P Be creative, it's an E30 :D
