no ressistor board found on heater
bav
Tue Jan 25, 2011 5:05 pm
i took apart a heater fan from an e30 in the scrapyard only to find that there was no resisitor board under the blower 8O , so i just took out the whole fan blower itself. the fan has 2 wires which attach to it will it still work if i just attach the fan on its own and connect the wires up into my bemma?
Tue Jan 25, 2011 5:08 pm
the resistor will be fitted to the side of the heater matrix if its not we you said with the blower
bav
Tue Jan 25, 2011 5:22 pm
yes i thought that it was on the side to but never heard of it before being located on the side of the actual fan, however if my ressistor bord is located in a different place i.e underneath the fan. will i still be able to fit this one?
