325i Sport- RENEWING SUSPENSION
r1chardc
Tue Oct 11, 2005 4:01 pm
Can anyone recommend a set-up for my Sport that will improve the handling but not crucify the ride? I am considering a bilstein streetline kit or possibly going to BMW for original replacement shocks?
garyp_E30_325i
Tue Oct 11, 2005 4:16 pm
I put a SPAX PSX kit on my 325i, lowers by ~40mm (would be ~15mm lower for a Sport) and is top adjustable (front, rear is on bottom - of course). There's the VSX kit too which is fixed rate at ~25% more than standard. I have mine set at pos 14 (half way) which is hard enough to make CD's jump on larger-ish bumps but gives fookin superb handling :D - you can change line mid bend without upsetting her, if you need to (too many sheep / drunks lying on the road up here :eek:).
Don't know much about the Bilstein but they're rep is good, I doubt they'd be bad. F&K are supposidly good too. Also Koni do an adjustable kit which comes in at ~Ԛ£329 - damn good price for Koni. I reckon any would be good, and better than the standard kit. Then there's coilovers, if you can face splashing out Ԛ£700 on suspension. 8O
If you're not sure about the firmness just go for the adjustables and set 'em up to suit yourself.
'89 325i - was an SE but not anymore, was bronze-beige metallic (yeuch!) but now techno-violet (thankfully)
'89 Toyota Corolla GTi-16 - track, hillclimb & sprint car (yeeha!)
'08 Buell XB12Ss - American engineering at it's 'best'... good fun though
6inline
Tue Oct 11, 2005 5:43 pm
Bilstein are excellent but not cheap
Koni/Eibach very good - have them myself. The ride is stiffer
Tue Oct 11, 2005 7:17 pm
H&R Cup kit for the money its unmatchable - Good price through the Zone shop also
Bushes are worth changing also
r1chardc
Wed Oct 12, 2005 11:08 am
Thanks guys, I reckon i'll go for the Bilstiens as they're rep is good and i'll probably change the bushes at the same time.
r1chardc
Wed Oct 12, 2005 11:09 am
r1chardc
Ceeman
Wed Oct 12, 2005 11:15 am
I have just had the H&R cup kit fitted to my sport and it is very impressive. Slightly lower and rides much better than it did on the old standard shocks and springs, handling was good enough for a day at Silverstone last week and that's before i had fitted the H&R antiroll bar kit. There are a few guys on here that have tried most of the suspension setups, H&R comes out the best and it's German too..... Sal in the Zoneshop will give you a good deal, give it a go. winkeye
