right guys had a wee a look at the car the other day and its needing front discs
just wondering what you guys recommend
new ones from bmw are 127 pound
can get other ones from local parts dealer for under 30
just wondered if you guys use anything else..
what brake discs to use??????????
- Brianmoooore
Pagid from ECP. These are cheap and OE quality, and Pagid is one of the world's biggest manufacturer's of brake discs and pads, and are the OE supplier to many makes.
Drilled/grooved discs won't improve braking performance in the slightest.
fuzzy
for an unmodified standard e30 the cheaper motor factor discs will be sufficient.unless your one of the type who prefers paying overinflated dealer prices for much the same parts because it has the bmw stamp on the packaging?
