Strange 'wind whistling' noise from back of car...
cgt
Wed Nov 10, 2010 2:27 pm
I thought it may have been a blowing exhaust but it looks like it's something else. It only happens above 20mph and increases with speed. Touching the brakes makes no difference, so can rule out pads.
It almost sounds like wind noise from a door seal or something but it's not that. Very confusing..any ideas guys?
Oh, car is a 316i Auto, 1990
Nikhil
Wed Nov 10, 2010 2:38 pm
I'm getting that same type of noise, but mine's a convertible and has a new roof so i'm not sure what it is.
Z3I
Wed Nov 10, 2010 2:59 pm
Often caused by items "sticking out" from your your, likes aerials, roof racks, spoilers, wing mirrors, body kits.
Check to see if you have anything like that.
Nikhil
Wed Nov 10, 2010 3:05 pm
Checked all that, any other ideas
realboss7669
Wed Nov 10, 2010 3:25 pm
cgt wrote:I thought it may have been a blowing exhaust but it looks like it's something else. It only happens above 20mph and increases with speed. Touching the brakes makes no difference, so can rule out pads.
You sure it isnt a wheel bearing or something? Other than that I get that noise, but only because my soft top is torn to shreads :mad: New one being fitted soon!!!
Nikhil
Wed Nov 10, 2010 3:38 pm
i think it may be the shims that sit under the roof i dont tink they have been put in right.
cgt
Wed Nov 10, 2010 7:39 pm
Hmmmmmmmmmm I have an aerial and a towbar. The aerial only stands semi-erect :mad: about six inches but the Towbar could be a suspect. It's annoying!
punko
Wed Nov 10, 2010 7:43 pm
iv had the same noise with every e30 iv owned i put it down to transmission noise not nececeraly a problem
leeparkes
Wed Nov 10, 2010 8:29 pm
Check your inner arches for holes
cgt
Wed Nov 10, 2010 10:01 pm
No rust I can see anywhere, car is surprisingly rot-free including arches. One garage I took it to was no help, they 'thought' it was the exhaust but it definitely is not. What a puzzle... :?:
cgt
Fri Jan 07, 2011 12:25 pm
Old thread but the noise is still there...! Not the exhaust, no rot under car (car as a whole is very rust free) and nothing obviously wrong?! Baffling. Car is a 2 door coupe by the way and it sounds like it's coming from the right rear corner.
The way I would describe the noise is if anyone remembers Jackie Chan's hotted up Mitsubishi in The Cannonball Run, it sounds exactly like that! :mad:
JJ26
Sun Jan 09, 2011 4:39 pm
I remember that noise and my 316i started doing it in its final miles. Sounded very much like a noisy pinion bearing to me. It was exceptionally noticeable when the car was first driven from cold on smooth roads. Couldnt rule out it wasnt the center prop bearing either. I never investigated further as i knew its end was nigh! lol
G/90 316i M40 tickety tic!
ST185 GT4
Archless! Tech 1 project
E46 330d Sport
JJ26
Sun Jan 09, 2011 4:43 pm
If the noise is definatly one sided then the only rotating part is the wheel bearing. Youve said touching the brakes makes no difference so id jack it up and have a good play with the wheel on the suspect side and see if it feels rough on rotation.
ST185 GT4
E46 330d Sport
cgt
Sun Jan 09, 2011 6:30 pm
Car is an auto, don't think they have pinion bearings and car has been checked over thoroughly by mechanic, meant to be in rude health (certainly runs very well).
Yes, I'm also suspecting a wheel bearing by eliminating other possibilities..,
mabz
Sun Jan 09, 2011 6:38 pm
i had this problem and it turned out to be the handbrake retainer clips which clip through the backing plates behind the discs,mine made a whirring noise.the backing plates are quite weak and the clips just pull straight through.hope this helps i knew mine used to bug me :x
JJ26
Sun Jan 09, 2011 8:34 pm
The pinion bearings are part of the differential, auto or manual makes no difference. :)
ST185 GT4
E46 330d Sport
cgt
Sun Jan 09, 2011 9:47 pm
mabz wrote:i had this problem and it turned out to be the handbrake retainer clips which clip through the backing plates behind the discs,mine made a whirring noise.the backing plates are quite weak and the clips just pull straight through.hope this helps i knew mine used to bug me :x
Thanks this might be the answer. Still dont think it's the pinion as I had a new diff and the noise was there both before and after.
xavier
Mon Jan 10, 2011 10:55 am
Let your wife out of the boot. then she will stop whistling
hezicar
Fri Jan 14, 2011 3:09 pm
I found that by changing the rear bushes the big large ones eliminated a lot of transmission noise etc
cgt
Fri Jan 14, 2011 3:27 pm
Looks like it's worn and rusty brake shoes on the back.
scrapdrifter86
Wed May 11, 2011 7:59 pm
its called transmission noise, most rwd cars have this noise, it may sound different in other e30z due to mileage, condition, or somebody like me or my mate punko abusing it before u owned it, i must say that yes the e30 is the loudest rwd car i have driven (transmission noise)
i hate sierras by the way
i drift scrap, an love it
lukescott
Thu May 12, 2011 9:11 am
The "wind whistling" sound you mention could well be the aerial . I was out recently in the convertible and noticed a wind / whistle sound from the rear........ turned off the radio & the aerial went down ....... guess what ? The sound stopped. Put your aerial down and listen.
