Lowering
StefanReindl
Besides making it look hella tight
, what effect does lowering the suspension have on handling/performance?
Hyperion
it generally tightens up the car, the e30 stock setup can give the car a sort of "bounce" "boaty" feel, its not really that bad, but it can be better. When you lower the car, it becomes more "sure footed" i feel, My car is still standard, and i am saving up to lower it, i think i am gonna go 35/35 on my car.
The effect all depends on what springs you use. Different springs have different spring rates, they might lower the same amount though.
All depends on what your looking for and what car you have.
Guest
my e36 is lowered and the handling of it has improved so much, u wudnt believe!!
the e30 is being lowered this month and if it half the effect i will be well pleased
What springs are you using?
lowering looks great handles well but the downside is eats tyres hates speed bumps dont like to carry more than 2 or on bad roads you will feel it
just raised mine back up smacked sump on a manhole cover crack she went damp things
- Emotechnik
- Contact:
Ruins traction and eats tyres!StefanReindl wrote:......what effect does lowering the suspension have on handling/performance?
