My M30 conversion
Bristol_Jer
Post Mon Jan 03, 2011 5:34 pm
Hi there,
Thought I'd start a thread for my M30 conversion, I'll be taking pics along the way so hopefully it might be helpful to others, even though it's been done loads of times before!
The car is a 320 facelift model so should be a straight forward swap (hopefully!). I bought the car off of a zone member last year and have done a couple of trackdays in it before I decided to do the engine conversion.
Plan is to do the engine conversion, tidy up the bodywork with a few patches of welding that need doing, convert the rear brakes to 325 discs and polybush what ever needs doing while it is off the road. It already has uprated suspension and yellowstuff pads, but I expect I will need bigger front brakes for trackdays.
Car parked up ready to be stripped, not much room to work but it's undercover at least:
Engine to go in, going to change oil, filter, plugs etc first. Trying to find a non dualmass flywheel and clutch to go on it but proving difficult so may settle for the dualmass I already have:
M535 radiator, compared to the standard M20 one:
Engine and box ready to be lifted out next weekend, prop, exhaust etc all off under the car:
leeparkes
Post Mon Jan 03, 2011 5:45 pm
About time :D
Bristol_Jer
Post Mon Jan 03, 2011 5:54 pm
Sorry for the delay, far too much :beer: over Christmas!
shedrool83
Post Mon Jan 03, 2011 6:55 pm
Nice one keep the updates coming i do like a build thread.
Post Thu Jan 06, 2011 3:49 pm
Nice, good luck 8)
staley_turbo
Post Thu Jan 06, 2011 4:01 pm
Aother m30 ftw :D
zaust
Zone day release
Post Thu Jan 06, 2011 4:17 pm
Nice, another m30 on the zone, can be made into a very livley engine too. great on track days. out the corners and blast down the straights awayfrom the jap crap. as for the yellow stuff pads, good choice i run mine with tar,ox discs and have no problems stopping at all. Boiling point becomes your enemy though so a high boiling point dot 5 or new pipes all round and the sylicon stuff can be used.
M30 Tech 1 Touring on gas.
chu346
Post Thu Jan 06, 2011 6:08 pm
zaust wrote:Boiling point becomes your enemy though so a high boiling point dot 5 or new pipes all round and the sylicon stuff can be used.
dot 5 is silicone, 5.1 isn't and is what you need if you don't want to change pipes.
What are yellow stuff pads like from cold?
Bristol_Jer
Post Thu Jan 06, 2011 6:09 pm
Thanks for all the comments :)
I should have the M20 out this weekend, and I need to make a big order with Cotswold to get engine/gearbox mounts, throttle cable, z3 shifter etc etc, then I can start thinking about getting the M30 in place.
Zaust, cheers for the advice on the brakes, I'll try my brakes as they are then and see how I go. I must admit I was very impressed with my Yellowstuffs the last 2 trackdays I have done. I did get them fading, but to be fair I was doing a lot of hard braking from 100mph+ and the fluid is god-knows how old!
zaust
Zone day release
Post Fri Jan 07, 2011 8:00 am
When cold they are cr*p, But they warm up very quick and bite well.
Bristol_Jer
Post Sun Jan 09, 2011 7:08 pm
Out it comes :)
Picked up my 325 rear trailing arms today as well
Next job is to fit the e36 rack I've had for ages, and get the M30 ready to fit
leeparkes
Post Sun Jan 09, 2011 9:39 pm
What diff you going to use?
Bristol_Jer
Post Sun Jan 09, 2011 10:03 pm
I've got a 3.64 for now, but think I'll probably go for the 3.91 as it will be a track car
Post Sun Jan 09, 2011 11:45 pm
3.73 for track will be better
Bristol_Jer
Post Mon Jan 10, 2011 6:49 pm
Are they easy enough to get hold of Rav? I'm just going to try a few different ratios using open diffs for now, and when I find one I like I'll get a LSD in that ratio
Post Mon Jan 10, 2011 9:15 pm
3.73 aren't plentyful, 3.64 would be better, a 3.91 will br revving it's bolloks of in 1st and no Top end really either.
leeparkes
Post Mon Jan 10, 2011 11:41 pm
I too would avoid a 3.91 ratio, a 3.73 is id say on the limit with an M30, any higher and first gear is gone. You dont need a short diff with these engines because of the huge torque curve. i will be going back to 3.64 as imo its the perfect ratio for what i need.
Bristol_Jer
Post Tue Jan 11, 2011 8:34 pm
Ok, I'll give the 3.64 a go and if a 3.73 comes up I'll give it a try as well :)
Minor update, have given the engine mounts a coat of Hammerite tonight!
Bristol_Jer
Post Sun Jan 16, 2011 5:13 pm
Took out the steering rack today and getting the e36 rack ready to fit. Should have my starter and alternator back this week, the auto electrician who works with my dad is reconditioning them for me. One less thing to go wrong when it's all put back together!
Going to a few scrapyards next weekend to get an electric cooling fan and 328 prop
leeparkes
Post Wed Jan 19, 2011 5:27 pm
Bristol_Jer wrote:Took out the steering rack today and getting the e36 rack ready to fit.
Let me know how you get on with the exhaust manifolds clearing steering coupling :D Got to do the same job myself :(
gareth
Post Thu Jan 20, 2011 12:13 am
Me too, i've got a Z3 rack ready and waiting, but i know it'll be a painful weekend. I hate exhausts :(
keri-WMS
Post Thu Jan 20, 2011 1:42 am
Bristol_Jer wrote:..I'll try my brakes as they are then and see how I go. I must admit I was very impressed with my Yellowstuffs the last 2 trackdays I have done. I did get them fading, but to be fair I was doing a lot of hard braking from 100mph+ and the fluid is god-knows how old!
You can tell if you get fade from overheated fluid because the pedal goes soft.
If the brakes stop working but the pedal stays hard then the pads gave up first.
Hope that helps! :cool:
Bristol_Jer
Post Thu Jan 20, 2011 11:16 am
In that case it was the fluid as the pedal went soft, thanks for the info :thumb:
keri-WMS
Post Thu Jan 20, 2011 12:29 pm
No problem! :D
Bristol_Jer
Post Thu Jan 20, 2011 12:49 pm
Will do! Just got to get some pipes sorted out, then I can trial fit the engine and see what I need to take the grinder to! winkeye
leeparkes
Post Thu Jan 20, 2011 8:05 pm
Get some pics up when you tackle it buddy, ie where you had to make the cuts. :)
Bristol_Jer
Post Sat Jan 22, 2011 5:28 pm
I'll be taking plenty of photos Lee :)
Went to 4 different scrap yards today to get some bits, couldn't find a 328 prop, but did manage to get a nice big cooling fan and mk1 Golf servo:
Had a quick play with the steering rack, I've got the spacers sorted to mount the rack and a solid aluminium guibo in place of the rubber one so that all fits ok. Should hopefully have the engine and box together soon to trial fit the engine and find out how everything fits together! I'll probably look to getting one of the solid bars for the end of the column if clearance is still an issue. I'll sort some pics of the rack progress tomorrow as it's too dark to get a decent photo now.
Post Sat Jan 22, 2011 6:58 pm
You don't need to change the E30 servo for the Golf one, it all fits in the bay as it is. :cool:
gareth
Post Sun Jan 23, 2011 2:02 am
was that fan originally mounted in front of the rad or behind? I ask as i had a brain fart when using a pair of shitroen BX fans on my M30 conversion originally. They were supposed to go behind the rad but i reversed them and put them in front. the problem came to light when it blew hot air forwards (!) then it occurred to me that the aerofoil on the fan would be the wrong way round. I reversed the polarity to spin them the other way but they were terribly inefficient and were later replaced with a fan that was the right way round :o: :D
Bristol_Jer
Post Sun Jan 23, 2011 6:03 pm
Rav335uk wrote:You don't need to change the E30 servo for the Golf one, it all fits in the bay as it is. :cool:
I was thinking ahead, may need some extra room in the future for boost pipes etc.... winkeye
Bristol_Jer
Post Sun Jan 23, 2011 6:05 pm
gareth wrote:was that fan originally mounted in front of the rad or behind? I ask as i had a brain fart when using a pair of shitroen BX fans on my M30 conversion originally. They were supposed to go behind the rad but i reversed them and put them in front. the problem came to light when it blew hot air forwards (!) then it occurred to me that the aerofoil on the fan would be the wrong way round. I reversed the polarity to spin them the other way but they were terribly inefficient and were later replaced with a fan that was the right way round :o: :D
It's an e36 A/C fan, was mounted in front of the rad so all good there :)
gareth
Post Sun Jan 23, 2011 11:44 pm
spot on :)
Hope you also got the two speed fan switch/sender from the rad? This will allow you to use the original low speed resistor and have a nice two speed setup at two temperatures. (essentially replicating the aircon E30 fan wiring)
Bristol_Jer
Post Mon Jan 24, 2011 9:40 pm
I didn't unfortunately, but they had loads of e36's there so will just pick one up next time I'm there :)
leeparkes
Post Mon Jan 24, 2011 11:21 pm
Im sure ive read you can transfer the whole e36 fan loom to the e30.
gareth
Post Tue Jan 25, 2011 7:09 pm
That would make sense, the E30 one seems to be an additional loom. I made my own loom up and routed it OEM stylee, even using the correct relay positions / fuses in the fusebox. :cool:
the wiring diagrams here will help a lot with this, very clear and easy to follow.
http://www.autolib.diakom.ru/CAR/BMW/19 ... 0DIAGRAMS/
you're looking for the wring to/from the high speed relay and low speed relay in the fuse box.
