As most of you probably know, I built my latest engine looking for a nice flat torque curve rather than the bragging rights that big BHP brings.
So, the engine spec is;-
eta bottom-end fully rebuilt.
731 'head fully rebuilt to standard spec, but it's been skimmed twice and only has 2 "references" left. I've no idea what the c/r is now, but I'd guess it's nearer 10.5 than the standard 10.2.
325i cam, TB, injectors and AFM.
320i inlet manifold with the throat relieved as much as I dared to make the most of the bigger TB.
Standard "log" manifold - no intention to replace this as I'm running an E36 'rack and don't want to throw mega-money at a BTB3.
I haven't a clue what spec. the chip is, although it's marked "Alpina 2.7".
The LPG set-up is;-
OMVL R90E vap.
Millennium/Leonardo closed loop control with the O2 sensor in the front down-pipe
Mixer downstream of the AFM with 39mm venturi
Iwema vacuum-operated AFM flap opener.
I've been wanting ever since I started running LPG to get an ignition map suited the LPG. For 3 years I've been running into dead-ends - until today.
At the moment, the engine runs far better on LPG than it does on petrol.
The "AFM delete" that the engine runs with on LPG
and
the dubious generic chip in the ECU.
I rarely run on petrol, other than for very cold starts, these days. This morning I decided to drive to Motoscope (50-odd miles from home) on petrol to see what it's like. It feels like the mixture is weak at low revs, the car has a bad jerk which isn't there on LPG. Also, I'd never realised just how much difference AFM-delete makes. The throttle response on LPG is far better than on petrol, but part of this is undoubtably down to the petrol fuelling being "off". It's fine cruising at a constant(ish) speed. On a flat bit of road, with no wind, holding 3k rpm, the swing-o-meter was showing 30+mpg.
So this morning, Richard has done a power run, on LPG, so that I have a base-line for the mods and as a comparison against a standard 325i (on petrol) purely for my own geeky interest. When I go back to have the W.A.R chip set-up, I'll have petrol figures as well for an "ultimate petrol/LPG comparison".
The current figures are 161bhp and 179lbft. The 325i on the same rollers made 176/165.
Comparing the figures at 500rpm intervals, my engine is at least 10bhp up on the 325i (8bhp up at 2k rpm) all the way from 2.5k to 4.5k, after which the gap narrows and my engine stops making power at 5.4k at which point the 2.5 is making 5bhp more and in another 600rpm it finds 11bhp on top. The torque graphs are pretty similar-shaped, but at 2k the 2.7 is 22lbft up and at 4.5k it's still 10lbft up.
I'm not planning any internal changes to the engine. The furthest I may possibly go is getting a cut-and-shut mod done on some spare inlet manifolds to get the 325i TB to fit properly on the 320i runners.
I had thought about getting a Miller MAF to go with the W.A.R chip, but I can't see the point at this stage. IF I ever get 'round to upgrading the LPG front-end to sequential, then I will fit a MAF. But as long as I stick with the single-point LPG, it's not necessary.
I also want to have a go at mounting the LPG mixer directly to the TB at some point, which will mean ditching the standard inlet boot and fitting a silicon elbow, and I'll have to figure-out a way of getting mixture through the ICV.
The aims of fitting the W.A.R chip are;
Hopefully find a few more LPG mpg by getting the ignition timing right for the higher RON of LPG.
Getting both the fuelling and ignition right for running on regular unleaded. Currently I'm having to use Super, because it pinks badly on regular. I'm not bothered if doing this sacrifices a bit of power due to the very limited time the engine ever runs on petrol. I just want it right in case of unavailability of LPG - such as when we're touring 'round the far north of Scotland.
I think I'm about 15-20bhp and roughly 10lbft down on what the engine ought to be capable of. But at the end of the day, if all I achieve is to improve the mpg by 10%, I'll be happy. Any power and torque increases will be a bonus.
The W.A.R chip will be ordered this week. Watch this space..........
