323i choke
alexdkj
Sat Dec 18, 2010 6:52 pm
Hi guys, just wonering how you can remove the autochoke, or reduce the revs when its on on a 1985 323i,
cheers
Sat Dec 18, 2010 8:11 pm
by fitting a new slider valve, they are about £120 from the dealers, :D
eltel
Sat Dec 18, 2010 8:15 pm
are they hard to set up or just bolt on??
Only in the good lord we trust.. In everything else we check!!
1988 325i Tourer, Lowered, Deep Dish Alloys, Obc, Cruise Control, Heated Leather Sport Seats....
petrol_1
Sat Dec 18, 2010 8:46 pm
Take it off and clean it out , then put in in water and boil it up slowly
it should be open when cold and close up when hot .
i had to help the spring push down the pistion at first after cleanng it out , but now its work fine
its also a v good time to flush and replace the old antifreeze too !!!
hope this helps
kyland
Wed Dec 22, 2010 3:36 am
There is an idle speed adjustment on the drivers side of the inlet manifold...look for a barrell shaped unit facing the firewall with a few vacuum hoses of it...someone may have adjusted this to compensate for the faulty air-slide valve. Of course, you will need to re-adjust after replacing the valve!
